Author Topic: Pixinsight extremely slow reading Canon EOS raw fits files  (Read 4567 times)
Offline cbradshaw
    • Charlie's Tree House Observatory
Recently, I've been trying to process Canon 20d DSLR raw fits files (captured and saved as 32-bit fits by Nebulosity) and Pixinsight is incredibly slow (~ 10-15 minutes to read all three layers) reading these files.  I don't remember this happening before.  Is there something in recent updates that may cause this.  I've tried it on two computers (a 32-bit Vista and a 64-bit Win7) and both are very slow.
Nebulosity reads the same files in seconds.
Charlie
Charlie - G11, CGEM, SV115T20, Meade SN8, Mod Canon 20d and T3, QSI 683 WSG,
Offline Cleon_Wells
Re: Pixinsight extremely slow reading Canon EOS raw fits files
« Reply #1 on: 2011 December 14 09:43:34 »
Charlie, are you talking about Image Integration when you say reading?
Cleon
Offline cbradshaw
« Reply #2 on: 2011 December 14 11:05:58 »
No!  Just opening the file.
« Reply #3 on: 2011 December 14 12:58:26 »
How large is the fits file? How large is your RAM?
Offline cbradshaw
« Reply #4 on: 2011 December 14 15:23:01 »
The files are 6059 kB.  On the 32 bit machine, I have 2GB and, on the 64-bit machine, 8 GB. I can load a 93,000 kB RGB fits file in 1-2 seconds on the 64-bit machine and ~ 5 seconds on the 32-bit machine.
Charlie
« Reply #5 on: 2011 December 15 01:00:41 »
Hmm, 6 MB is not really large. Maybe you upload one of the problematic files somewhere, so people can test. Also, this way Juan can have a look when he finds time.
Offline cbradshaw
« Reply #6 on: 2011 December 15 04:14:56 »
I was going to crop the image to see if the effect continued when saved by Pixinsight, but got the following error:
PCL FITS Format Support: FITS file write error:
CFITSIO error message stack:
01: Error reading PCOUNT keyword value as an integer: 9690800
02: Failed to read the required primary array header keywords.
I loaded the file into Pixinsight and cropped with Dynamic Crop to reduce the file size.  This error occurred with the Save As function.
Charlie
Offline cbradshaw
« Reply #7 on: 2011 December 15 15:00:43 »
I've solved my problem.  In Nebulosity, I checked "save as compressed fits" to save disk space.  Apparently, Nebulosity either incorrectly compresses the file or Pixinsight incorrectly reads the file, which results in the save error.
I unchecked "save as compressed fits" and had Nebulosity do a 2x2 binning of all files.  After the files were binned and saved, I checked the fits header and it was normal and without compression.  The binned files loaded correctly and quickly in Pixinsight.
Regards and thanks,
Charlie
« Reply #8 on: 2011 December 15 15:16:51 »
oh phooey, i've had that happen before with files coming out of maximDL. i guess compression is just One More Thing that's not defined in the FITS standard and everyone does it differently.
