Author Topic: ImageInsert Script  (Read 9978 times)
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
ImageInsert Script
« on: 2011 December 11 17:36:46 »
I wrote a little script that allows you to insert a small image in a bigger one, like this example:
Supernova SN 2011iv
The settings are simple: you select the images (big and small), location, margins, and optionally a border width and border color. Here a UI screen capture:
I am almost certain that there must be a more efficient way of doing that which I have used, but still it was fun. I used the classic way of crop and PixelMath (like the manual way), with a little math.
Enjoy ;)
Enzo.
Re: ImageInsert Script
« Reply #1 on: 2011 December 11 18:20:48 »
Excelente!, funciona perfecto. Muchas gracias Enzo.
Saludos. Alejandro.
Offline Fco. Bosch
« Reply #2 on: 2011 December 13 08:58:12 »
Thank you Enzo! Would be possible to selec the insertion area with the mouse, like a preview ... ?:sad:
Fco. Bosch
    • Astronomí­a Sur
« Reply #3 on: 2011 December 13 09:59:36 »
I'm afraid that is beyond my current abilities :-[ But you can play with the predefined locations and margin values to locate the inset in, I think, any part of the main image (with some predefined maximum values for now) Anyway, can be tricky to locate at a specific point.
Enzo.
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #4 on: 2011 December 13 11:33:02 »
Hi Fco.!
If you dont mind to insert "circular" images from one picture to the other
the process CloneStamp can be used the way you want with the mouse.
Here the description how i did it before Enzo announced his great tool.
(Thanks Enzo)
Insert Images, or part of one, or more images to another one:
R=Receiving Image
I=Inserted Image(s) (Usually out of one or more small images created out of preview(s)!!)
Part One:
Make R active Image
Call Process CloneStamp
Press Reset on CloneStamp
Set Radius to I / 2  (use w or h  in bottom line of Window of I)
Part Two:
Move Mouse to Center of I and Press Ctrl and left mouse,
Release Ctrl and left mouse,
move mouse to R and where you want the image I inserted,
Click left mouse,
You can repeat Part Two as often as you want (also with different I`s)
Click green execute on CloneStamp process window.
Close ConeStamp!!
Finished
or Start from Part One.
Aloha
Gerald
Offline Fco. Bosch
« Reply #5 on: 2011 December 13 12:47:18 »
Thanks Gerald! I misuse clone stamp ...
Fco. Bosch
