Author Topic: mosaic of the Antares region  (Read 5345 times)
Offline Edmund_Georgii
    • Astroveto
« on: 2011 November 16 11:39:30 »
first attempt to make a mosaic of 9 frames from the Antares region at this summer 2011
Optics 180 Epsilon f2,8 and a QHY12 Color CCD.
9 x10 x600 sec during several nights in June 2011.
I still have some gradients near the image borders, but at the moment I'm quiet happy with my first mosaic.
Antares mosaic
CS
Cheers
Edmund
Astro-Blog
Offline Lex
  • We do it at night...
Re: mosaic of the Antares region
« Reply #1 on: 2011 November 16 12:06:47 »
Edmund,
Your first attempt of a mosaïc is quiet impressive, the panels have the same levels an everyting is pingpoint, really nice!    8)
The only thing that could be changed IMHO, would be to more restrictively proceed with the DBE tool, perhaps a SCNR to supress some greenish touch an finally a manual Histogram stretch to "calm down"
the background, these applied to the finished merge..
Edmund, great Job on a 9 panel mosaïc, what is really not easy game!
Clear Skies!!
Lex
« Reply #2 on: 2011 November 16 14:02:17 »
Hi Edmund,
Nice mosaic. You can try attached process in order to reduce a little crominance and green noise and to highlight dark nebulaes
Saludos.
Alejandro.
    • Astroveto
« Reply #3 on: 2011 November 16 14:25:49 »
Hi Lex , Alejandro
thanx for your imput and and I have followed your advice  ;)
Voila the  result
antares-mosaic-2
CS
Cheers
Edmund
Astro-Blog
« Reply #4 on: 2011 November 16 16:30:34 »
it is a graet picture!
Saludos.
Alejandro.
Offline jtalbot
    • http://www.starscapeimaging.com
« Reply #5 on: 2011 November 16 18:45:03 »
Wonderful image Edmund.  Congrats.  If you live were gradients are present, you should learn the DBE tool.  It works very well.  I have to use it with every image I produce from home and is the only reason I can do color from my backyard.  One tip when using it.  If your images cross the meridian, your gradients will change.  Either plan to image on one side with a particular filter or stack the individual frames from one side at a time and correct them first prior to combining them.  It makes gradient correction much easier.
Jon Talbot
Clear Skies
Jon
Offline Lex
« Reply #6 on: 2011 November 17 03:28:38 »
Edmund,
one word WOOOOOWWW,
nice job  ;D
Clear Skies!!
Lex
    • Astroveto
« Reply #7 on: 2011 November 17 04:46:09 »
Thanks  you all
@Alejandro
How to do this , I mean run your file in PI ?
« Last Edit: 2011 November 17 04:52:11 by Edmund_Georgii »
CS
Cheers
Edmund
Astro-Blog
« Reply #8 on: 2011 November 23 19:44:38 »
Yes, save the attached process, drag it on Pix workspace and then apply it to the final picture that you posted.
Let me know if you have any doubt.
Saludos!
Alejandro
Offline Ginge
« Reply #9 on: 2011 November 24 05:19:21 »
This is a great image Edmund! The first one was good and the second is really beautiful! Well done.
Is there a little artifact from the GradientsMergeMosaic process on the second brightest star in the upper left corner?
Best regards,
Ginge
astropixel
  • Guest
« Reply #10 on: 2011 November 25 01:29:23 »
Subtle, understated and beautifully presented. A favorite. Very nice
    • Astroveto
« Reply #11 on: 2011 November 25 23:52:14 »
Thanks  you all  :)
@ Alejandro
Ok, but I can't drag it on the Pic workspace . :'(
how you do it exactly ?
« Last Edit: 2011 November 26 02:20:43 by Edmund_Georgii »
CS
Cheers
Edmund
Astro-Blog
