Author Topic: Installation in Fedora  (Read 4563 times)
« on: 2011 November 06 09:39:51 »
Hola,
Instalé PixInsight en Fedora con Gnome 3.0.1. Luego de la instalación me dice que hay  12 updates, los instalo y luego de bajarlos todos Pix se cierra solo. Luego no puedo volver a abrirlo si no reinicio la pc.
Cuando inicia nuevamente vuelve a indicar que están los 12 updates y se repite el proceso.
No tengo experiencia con Fedora, alguna idea qué puedo estar haciendo mal?
Hello,
I have installed PixInsight in Fedora with Gnome 3.0.1. After installation tells me that there are 12 updates, I select install and after download Pix closed alone. Then I can not reopen it if I do not restart the pc.
When it start again indicate that there are 12 updates and repeat the process.
I have no experience with Fedora, any idea what I am doing wrong?
Saludos.
Alejandro.
astropixel
  • Guest
Re: Installation in Fedora
« Reply #1 on: 2011 November 09 00:26:03 »
Hi Alejandro. After downloading the updates and closing PI - don't reboot - instead, go to the pixinsight/bin directory and open a terminal in that folder (or just open a terminal and cd to the directory) and type;
$./Pixinsight
I'm not near my PI computer so it could be
$./pixinsight
See if PI starts, if not, note any error messages. Alternatively refer to the log file if it exists. That might give you a better idea of what's going on.
Or, just delete the installation and try again.
« Reply #2 on: 2011 November 25 12:17:43 »
Hi Astropixel,
Thanks for your help. I tried writting "$ ./PixInsight.sh"  it and gives the following error:
[admin@localhost bin]$ ./PixInsight.sh
** A previous instance of the PixInsight Core application crashed.
Reusing instance slot #1.
(<unknown>:19258): GdkPixbuf-WARNING **: Bug! loader 'png' didn't set an error on failure
(<unknown>:19258): Gtk-WARNING **: Error loading theme icon 'dialog-information' for stock: Internal error: Image loader module 'png' failed to complete an operation, but didn't give a reason for the failure
(<unknown>:19258): GLib-GObject-CRITICAL **: g_object_unref: assertion `G_IS_OBJECT (object)' failed
** (<unknown>:19258): CRITICAL **: clearlooks_style_draw_render_icon: assertion `base_pixbuf != NULL' failed
(<unknown>:19258): Gtk-CRITICAL **: IA__gtk_style_render_icon: assertion `pixbuf != NULL' failed
(<unknown>:19258): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_pixels: assertion `GDK_IS_PIXBUF (pixbuf)' failed
(<unknown>:19258): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_width: assertion `GDK_IS_PIXBUF (pixbuf)' failed
(<unknown>:19258): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_height: assertion `GDK_IS_PIXBUF (pixbuf)' failed
(<unknown>:19258): Gtk-WARNING **: Error loading theme icon 'dialog-error' for stock: Internal error: Image loader module 'png' failed to complete an operation, but didn't give a reason for the failure
./PixInsight.sh: line 9: 19258 Segmentation fault      (core dumped) $dirname/$appname $*
« Reply #3 on: 2011 November 25 12:31:10 »
Which version of Fedora? Fedora 14 works fine for me.
« Reply #4 on: 2011 November 25 21:11:04 »
Hi Georg,
It is Fedora 15
Regards, Alejandro
« Reply #5 on: 2011 November 26 02:42:19 »
Hi Alejandro,
Sorry for overlooking this post  :-[
This is a GTK error (look at the two lines starting with 'Error loading theme icon ...'). I've seen it with GNOME 3 and also one user has reported it with GNOME 2.6. Could be some update that has broken something.
If you're running Fedora 15 then you're probably using GNOME 3. PixInsight runs without flaws on GNOME 2.x (with the possible exception I've mentioned above), Xfce 4.6 and 4.8, and the latest versions of KDE. We'll try to fix these problems with GNOME 3 in the next release; however, we can't promise anything because GNOME 3 is 'evolving' too quickly (I'd rather say it's 'self-destroying', but that's another story).
For stability and performance, I strongly recommend you run PixInsight on Xfce or KDE. If you have the Fedora 15 DVD it comes with KDE ready to install. The same for Fedora 16.
