Author Topic: November 2011 Contest Images  (Read 10128 times)
Offline Javio
  • Moderator
    • PixInsight
« on: 2011 November 02 07:51:35 »
The November 2011 PixInsight Monthly Astrophotography Contest is open. Please use this post ONLY to submit your images.
Good luck!
Javier Sanchis Muñoz
Offline jeffweiss9
Re: November 2011 Contest Images
« Reply #1 on: 2011 November 05 09:47:41 »
Ok, I'll try entering an image for this month's contest:  NGC7012 Iris Nebula
http://www.astrophotogallery.org/member-galleries/p8355-ngc7023-iris-nebula.html
Scope used: APM 130/780 f/6 LW CNC II
Mount Used: Takahashi EM-200 Temma2
Camera Used: SBIG ST-2000XM Astrodon Gen2
ISO/Exposure: Total: 4.3 hrs; L: 2.5 hrs (8min) RGB: 1.8 hrs (4min 2x2)
Seeing 1-10: 8
Processing entirely in PI:  Calibration, Registration and Stacking, LRGB Comb (Vicent's tutorial methodology), HDRWT, ACDNR, CT and a bit of sharpening with AWT.
-Jeff
« Last Edit: 2011 November 05 09:58:51 by jeffweiss9 »
Offline Andrés Vattuone
« Reply #2 on: 2011 November 16 17:53:39 »
Hi, I would like to share this picture. Processing in colaboration with Alejandro Tombolini
Details:
Object: NGC 2070
Camera: SBIG ST 8300 M
Telescope: Tacahashi FSQ 106 ED - Focal Leng 530 mm - f/5
Number of images: RGB 16 X 180 seconds. L 15 X 120 seconds.
Total Time: 1 hours 18 minutes
Program: PixInsight
Comments: Guided with SBIG SG4 and AstroTech 72 mm from Intendente Alvear - La Pampa - Argentina
Main Processes:
Dynamic Crop
DBE
Color Calibration
Masked Strech
Histogram Transformation
ACDNR
HDRMT
Curves Transformation to nebula without stars
Color Saturation to nebula without stars with rangeMask
SCNR to green
GREYCstoration with LMask
Morfological Selection to stars
HDRWaveletsTransform
LocalHistogramEqualization
MMT
UnsharpMask
http://3.bp.blogspot.com/-v8TQSnxcrgU/TsRep8UBuSI/AAAAAAAAAJA/glBnHDluvdU/s1600/ProximaSur+NGC+2070+1600X1059.jpg
Andrés
« Last Edit: 2011 November 20 12:01:02 by Andrés Vattuone »
Offline jtalbot
    • http://www.starscapeimaging.com
LBN 438
« Reply #3 on: 2011 November 18 18:41:55 »
Image of LBN 438 taken at the Chiefland Star Party, Chiefland, FL 23-26 Oct 11
Optics: 10" Carbon Fiber Astrograph @f3.8
Camera: QSI 583 with Astrodon 31mm LRGB filters
Images: Luminance 380min, 10min subexposures
R: 160min 10min subs, G: 160min 10 min subs, B 190min 10min subs. RGB bin 2x2
Processing:
Star alignment of all subframes
Dynamic Crop
DBE
Color Calibration
SCNR
Histogram Stretch
RGB combine
ACDNR
LRGB combine with Color saturation
Higher res image here: http://www.starscapeimaging.com/page64/index.html
Jon Talbot
Clear Skies
Jon
Offline Giorgio
« Reply #4 on: 2011 November 19 02:21:54 »
Hello everyone,
I show you this reflection nebula vdB152 gave me a lot of work.
Data: 16.10.2011
Object vdb-152
Optics Takahashi FS128
Mount 10micron GM2000
Camera Apogee Alta U8300
Chip Temp -25 C.
Filter Optec LRVB
Exposure L 540'bin1, R 180' V 180' B 180'bin2.
Camera/Mount Control   Maxim DL
Software calibration processing PixInsight
http://www.flickr.com/photos/53758843@N03/6311745889/
Giorgio.
Offline Howard
    • Cabin in the Sky Observatory
« Reply #5 on: 2011 November 20 02:43:00 »
Hi Javio:
I'd like to submit the following rendition of the Ghost Nebula, a modified version of an image that I posted to the Gallery in October.
Processing was done entirely with PixInsight, except for use of CCDInspector to evaluate subexposures and to monitor overall specs during processing.
Image capture details
Telescope: PlaneWave CDK17, with a focal reducer at f/4.5.
Mount: Paramount ME.
Camera: SBIG STL-4020M.
Exposures: Total of approximately 15 hours: about 6 hours luminance unbinned, and about 3 hours in each of red, green, and blue with 2x2 binning; 10 minute subexposures in all channels.
Flat field correction: using twilight flats.
Image capture: TheSkyX, MaxIm DL, FocusMax.
Image scales: Unbinned pixel size 0.78", frame about 25' on a side.
Imaged between August 6 and 26 2011 from rural British Columbia, Canada.
PixInsight processsing highlights
LUMINANCE:
Deconvolution (reduced Aspect ratio and nonzero Rotation to correct for guiding problems on gusty nights) ; ATrous (star masked, positive bias on layers 3 and 4 to increase contrast on extended nebula structures); UnsharpMask (applied to brightest core region of nebula); ACDNR (luminance mask).
CHROMINANCE:
RGB BackgroundNeutralization; LRGBCombine (Saturation=0.15); CurvesTransformation (mild additional saturation boost); Histograms (colour balance and black point); MorphologicalTransformation (2-way Morphological Selection to circularize and erode small stars); CurvesTransformation and UnsharpMask combination tailored for bright stars (to reduce halos and sharpen cores, modified from earlier version).
Best wishes to all,
Howard.
Obsessed with the photographic experience of the cosmos!
Cabin in the Sky Observatory: PlaneWave CDK17, Paramount ME, Apogee U16M, Astrodon filters & MOAG, Starlight Lodestar, in a roll-off roof under the deep, dark skies of rural BC Canada.
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #6 on: 2011 November 20 06:22:58 »
Hello
Here is NGC7000 in HaRGB (RGB is a mix of SII Ha OIII)
QSI540WSG on FS60CB 0.72x at 255mm f/4.2
Ha 13x20min
SII 8x20min
OIII 8x20min
PI full processing
full res here :
http://www.astroccd.eu/images/ngc7000-HaRGBtr-100pc.jpg
Cheers
Philippe
