Author Topic: SBIG ST-4000XCM DeBayering  (Read 5589 times)
Offline wlickteig
« on: 2011 October 16 13:15:30 »
It doesn't appear the deBayer routine is working.  I run the script with it set to Bilinear and RGGB and  then click execute.  It executes, but when I look at an individual image, I still see the Bayer matrix "cross-hatching".
Thoughts?
Walt Lickteig
Re: SBIG ST-4000XCM DeBayering
« Reply #1 on: 2011 October 16 17:20:02 »
Sounds like your RGGB setting is not the one you should use.
Offline ronk01
« Reply #2 on: 2012 January 13 06:00:57 »
Can someone please tell me the proper parameters for debayering an SBIG 4000XCM light image that has already been calibrated.
regards,
ron k.
« Reply #3 on: 2012 January 13 08:02:05 »
dont know but you can easily try them all for yourself. gets easier if you take a daytime photo with the camera.
« Reply #4 on: 2012 January 13 08:04:42 »
There are only 4 choices so a little experimentation does not take a lot of time. The following shows an easy method if you don't know how to proceed.
http://qhy8.wikispaces.com/How+do+I+verify+my+colors+are+correct%3F
Offline ronk01
« Reply #5 on: 2012 January 13 12:51:43 »
Sander,
I followed your suggestion and found out that what works for an SBIG ST-4000XCM is GRBG. I just happen to have started running software on a new computer and your process led me to look at the Maxim DL debayer settings that were not set to SBIG ... so you solved two problems. I'll have to go through a few images to see what difference there will be in the color rendering.
regards,
Ron K.
« Reply #6 on: 2012 January 13 12:55:24 »
Ron,
glad to help. I think you'll agree that learning how to fish beats getting a fish handed to you :)
