Author Topic: Color calibration - how?  (Read 9395 times)
Offline viktorcech
« on: 2011 August 24 02:33:55 »
Hello,
i have pretty red pictures.. how can i doo color calibration? i open CB tab, then i select preview, use that preview in CB.. and result is that same red background i have.. hmm
Re: Color calibration - how?
« Reply #1 on: 2011 August 24 05:31:03 »
First do background neutralization or DBE, then color calibration.
Offline sreilly
« Reply #2 on: 2011 August 24 07:51:38 »
I do my color calibration after the image has been cropped to ensure rgb borders all around and has had a Dynamic Background Extraction or Background Neutralization process done. As I dither my images, after combining the red, green, and blue images, the border is usually overlapped. Cropping the RGB image ensures that there is RGB data in the entire frame. Now when I do any procedure there shouldn't be any area where one frame is/isn't represented. Now doing either the above and then color calibration I know the entire data set is sampled. Hope this makes sense.
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline viktorcech
« Reply #3 on: 2011 August 24 08:03:29 »
ok, first i use background extraction, then autostretch and then color calibration.. now i have 3 windows.. what next?
i try use histogram on that black window, but its only total black background..
« Reply #4 on: 2011 August 24 08:17:15 »
looks like you're struggling with some basic issues. Please take a few moments (hours) to view Harry's videos. They are linked from within PI.
Offline viktorcech
« Reply #5 on: 2011 August 24 08:19:02 »
i know basic issues, i only trying this CC, thats photo are not mine, i only use it for learning CC..
« Reply #6 on: 2011 August 24 08:38:42 »
I wasn't referring to your image. I recommend you review Harry's video about DBE as it will probably answer "now i have 3 windows.. what next?"
Offline viktorcech
« Reply #7 on: 2011 August 24 08:52:47 »
i see that video, i follow that steps, but results is on screenshot..
« Reply #8 on: 2011 August 24 08:59:54 »
Make sure your image is properly cropped so it does not include any weird borders. Steve already said that. Then do DBE and apply an automatic STF to the resulting images to see what you've got. Once you like the result you can choose to apply DBE to the source image or proceed with the generated image, that's up to you.
Offline viktorcech
« Reply #9 on: 2011 August 24 09:10:09 »
Ok, i  must shot some pictures, m42 maybe and i try it.. thanks and sorry, my fault :)
