Author Topic: Safe writing of project file  (Read 2997 times)
Offline robhawleyastro
« on: 2011 June 01 13:21:20 »
I notice the warning when you overwrite the project file.  The problem you describe is real, but there is a simple way to avoid it
           create project-tempxxx
           write update to project-tempxxx
           close project-tempxxx
           delete project
           rename project-tempxxx to project
With this technique the worst case is that the rename does not occur.
Of course since windows caches writes you are not really save unless you insert a flush to force the temp file to disk.
