Author Topic: Is this a correct flat ?  (Read 4610 times)
Offline JGMoreau
« on: 2011 March 22 07:15:11 »
I am wondering if my flat is correct. It was made by exposing for a few seconds on the evening clear sky
through a white bed sheet. My imaging scope is a Newtonian reflector.
I did as instructed by Vincent.
Most of my images after color calibration are too strong in red and/or lack blue.
Camera is SBIG ST-2000XCM one shot color.
Here is a screen capture of debayered flat and histogram :
http://www3.cablevision.qc.ca/astro/Flat_Histogram.jpg
As you can see the blue channel is off to the right.
Also, the flat is stretched (?)
Did i do something wrong ?
Your comments appreciated.
J Guy Moreau
Re: Is this a correct flat ?
« Reply #1 on: 2011 March 22 07:41:12 »
your flat looks fine even if it's a bit blue. Most likely you're not bias subtracting your flat or not dark subtracting your lights.
Offline Cleon_Wells
« Reply #2 on: 2011 March 22 20:28:54 »
Guy, here's what my MasterFlat looks like for my Canon T1i on my 10"RC.
http://www.astronomybycleon.com/files/page0-1004-full.html
I did not convert the MasterFlat to gray scale.
I took the subs at dusk and rotated the OTA 180 degrees for the last 5 subs with a total of 10 flat subs.
You should be able to see the vignetting of your optics when you stretch the MasterFlat.
Cleon
Offline JGMoreau
« Reply #3 on: 2011 March 23 05:53:44 »
Thanks Sander and Cleon for replying.
Sander, i think i do make the flat according to instructions,
and calibrate my lights as they should, but i will check again.
Maybe i have not made all the mistakes wet ;)
Cleon, i see that your flat is a linear image and you applied STF to make the content visible.
Well this is a clear sign that i goofed somewhere, the image in the link is my flat as it came
out of the making process and looks stretched!
Did you make it with PI ?
I made one with DSS and it is exactly the same, an autostretch lurking in the background ?
Hmmm, more testing is in order...
J Guy
Offline Cleon_Wells
« Reply #4 on: 2011 March 23 07:15:32 »
Guy, goto this link, it's for DSLR raw files witch I assume will work for you SBIG one shoot files.
http://pixinsight.com/forum/index.php?topic=2570.msg17312#msg17312
Yes I did every thing in PI.
Look at these MasterFlat comparisons on my web site, it's interesting that the debayered images from the Gray MasterFlat have a lower pixel level compared to the DeBayered image( lower left ) form my RGB MasterFlat.
http://www.astronomybycleon.com/files/page0-1005-full.html
Cleon
« Reply #5 on: 2011 March 23 08:09:48 »
i have noticed the same thing regarding signal levels in flats between files debayered with BatchDebayer and DSLR_RAW... i posted a question sometime back but got no answers.
Offline JGMoreau
« Reply #6 on: 2011 March 23 14:06:06 »
For me signal level is pretty much the same either with the script or with debayer module.
http://www3.cablevision.qc.ca/astro/Flat_Histogram2.jpg
My main concern is with the different distribution of pixels values as depicted on the histogram.
Does this introduce a color bias on my lights ?
Guess that my understanding of how flats works is inadequate :-[
Thanks Cloen for the link, will study.
JG Moreau
p.s. my latest :  http://www3.cablevision.qc.ca/astro/NGC3227-6.jpg
