Author Topic: Pixelmath  (Read 3180 times)
Offline Lex
  • We do it at night...
Pixelmath
« on: 2011 March 18 04:46:25 »
So,
Pixelmath is the right tool to combine L with L-frames or L with Ha-frames for instance, the rest of the deal has to be done in Color-combination or in LRGC-combination; am I right with this or what is the best way to combine several L-frames, or Ha ones?
Regards
Lex
Clear Skies!!
Lex
Offline Philip de Louraille
Re: Pixelmath
« Reply #1 on: 2011 March 18 07:32:30 »
To just combine (aligned) L with more L-frames, I'd use ImageIntegration.
To combine L with Ha, for instance, if you want to create a new channel, PixelMath is the one to use.
If you just wanted to combine a set of 3 or 4 channels, you could use LRGBCombination if all you want to do is change (or not) their individual weights.
For anything fancier, as in combining two frames in one channel with their own weight, then PixelMath is the one I'd use.
Philip de Louraille
Offline Lex
Re: Pixelmath
« Reply #2 on: 2011 March 18 17:02:25 »
Thats what i thought to, thanks for confirmation  :)
But do you know all the specs and hints of pixelmath, it's to huge for me to understand....
Regards
Lex
Clear Skies!!
Lex
Re: Pixelmath
« Reply #3 on: 2011 March 18 17:08:38 »
Start simple. Rename the frames you are going to use with very short & easy to remember labels.
Then ... oh well it is just easier for you to read this thread than me to rewrite it. ;-)
http://pixinsight.com/forum/index.php?topic=2513
Philip de Louraille
Offline Lex
Re: Pixelmath
« Reply #4 on: 2011 March 19 14:18:41 »
Thanks a lot, that helps me out of my math problem :-)
Regards
Lex
Clear Skies!!
Lex
