Hi Everyone,
I just did a search on the phrase `no correlation', to see if anyone has been having the same problem that I have. This has been a pretty big problem for me during the last few weeks.
I'm trying to calibrate monochrome CCD images that I shot with an Orion Parsec 8300M camera. I shot lights, flats, darks, and biases. I have prepared the master bias, dark, and flat frames according to the standard Pixinsight tutorial:
http://pixinsight.com/tutorials/master-frames/en.htmlAfter making these master frames, I've taken a quick look at each of them with an auto STF, and they look like images I've seen in books about CCD imaging, showing what the master frames `should' look like (e.g. Berry and Burnell, Wodaski).
I am applying these master frames to my light frames, using the Image Calibration module (The light frames also look normal with an auto STF).
However, when I try to calibrate my light frames, two strange things happen:
1) The processing console tells me that there is `no correlation' between my dark frame and my target frame.
2) I get a `calibrated' light frame that looks very strange... when I do an auto STF on it, it is perfectly gray, except for the brighter pixels, which are clipped to white. I call it a `binarized-looking' appearance. There is no useful data in the image. It's hardly even an image any more.
In the Image Calibration module, I've tried various combinations of checking and unchecking the `calibrate' and `optimize' boxes, in all of the places where they appear, without any luck.
I'm wondering if I'm just making a mistake, or if this might possibly be a bug? My darks, flats, biases, and lights were shot with the same camera, at the same temperature, and the same binning. They were saved at the same bit depth. (I get this problem both when I acquire everything at 16-bit and when I acquire everything at 32-bit depth).
There have been a couple of recent threads that have mentioned this issue:
http://pixinsight.com/forum/index.php?topic=2528.0http://pixinsight.com/forum/index.php?topic=2460.0I'm using 1.06.09.0652 eng (x86), running under Mac OS X 10.6 (Snow Leopard) on a MacBook Pro.
Thanks, hopefully this is just some simple mistake that I'm making. I hope to be able to calibrate frames again sometime soon.
- Marek Cichanski
