Author Topic: OPut of memory during HDR composition  (Read 2802 times)
Offline federico
  • A brilliant future behind
    • Business site
« on: 2011 February 14 04:27:54 »
HDRComposition continues to fo out of memory, but PI is the only program running, plenty of memory available.
WinXP 32 bit - 4 GB of memory, max occupied by PI duiring session: 840MB.
There are only 2 images, and both have been processed by Histogram
HDRComposition: Beging process
Images to combine, sorted in growing order of exposure time:
E:/challenge/M42_Core.fit
E:/challenge/M42_Outer_elab.fit
Reading image:
Reading FITS: 32-bit floating point, 3 channel(s), 3906x2602 pixels: 100%
Reading image:
** Warning [156]: C:/Programmi/PixInsight/src/scripts/HDRComposition.js, line 171: assignment to undeclared variable point
PixelMath: Processing view: M42_Core
Writing swap files...
62.03 MB/s
Calculating view statistics...
Solved 1 invariant subexpression(s).
Executing PixelMath expression: combined RGB/K channels:$T - Med(bA) + 0.05: 100%
Truncating to [0.0000000000,1.0000000000]: 100%
0.500 s
PixelMath: Processing view: M42_Outer_elab
58.60 MB/s
0.454 s
 aLh 0.6938696503639221,0.6844624876976013,0.6835164427757263
 aSh 0.10681696236133575,0.10095750540494919,0.10381857305765152
 aLl 0.2695162892341614,0.26815059781074524,0.26607537269592285
 aSl 0.07185854762792587,0.0677691325545311,0.06765469163656235
 S: 0.08238043558872657,0.07971997355020996,0.08663230336721688
PixelMath: Processing view: LongPrim
65.90 MB/s
*** Error: Out of memory
Reading swap files...
824.80 MB/s
<* failed *>
What is happening?
Federico
Re: OPut of memory during HDR composition
« Reply #1 on: 2011 February 14 05:48:53 »
Hi Federico,
This happens with the old HDRComposition script. You should use the new HDRComposition tool, which you'll find under the ImageIntegration category, on the Process Explorer window. This tool works much better than the script and does not have these memory consumption problems.
