Hi Antonio
I have an achromat too
The first I would try is to deconvolve the RGB channels separately. Specially the blue one. Then, play a bit with the morphological filters to reduce the size of the stars. You'll need to build a good star mask, to avoid destroying deep sky data.
If all of this fails, another solution could be to create a mask with only the haloes (for example, take a look at the ColorRange process I developed, at the bottom of the forum board, in the CMSegmentation module). Then use SCNR or curves to decrease the blue.
