Author Topic: PixInsight 1.6.9.651  (Read 19686 times)
« on: 2010 December 30 10:31:49 »
Hi all,
While I'm writing this, PixInsight 1.6.9.651 installation packages are being uploaded for all supported platforms.
Main Bug Fixes
The new version fixes a number of bugs and problems present in the initial 1.6.9 release. The most important bugs fixed are the following:
- Fixed timeout issues with the updater application on Windows Vista and Windows 7.
- Fixed a bug where the mouse wheel parameters were incorrectly modified by the PixInsight Core application (all platforms).
- Fixed a regression in the SCNR tool where the "Preserve luminance" check box was enabled by default, causing "surprising results".
- Fixed a bug in the DSSImageDownloader script where downloading gzip-compressed FITS images led to crash on Mac OS X, due to 'limitations' (to say it euphemistically) of CFITSIO.
- Fixed a regression in the DarkStructureEnhance script where execution failed due to an incompatibility caused by changes in the Rescale process.
- Fixed a regression in the MakefileGenerator script where the FreeBSD and Linux items where swapped in the Platform combo box.
- Fixed a bug in the AssistedColorCalibration tool by Zbynek Vrastil, where instances saved to XPSM/PSM files where not restored correctly.
- Fixed a number of minor issues with workspace windows on all platforms, especially on Mac OS X. The 64-bit Mac OS X version is somewhat better although some GUI issues still persist.
New Features
In addition, build 651 introduces two important improvements:
- The PixInsight Core application is now fully position-independent on all platforms. This means that once installed, you can move PixInsight Core to a different directory on the local filesystem without problems. The application does no longer store absolute paths to module and script files within the installation directory tree, but relative paths coded in a special format. The translation from the previous format is automatic and transparent the first time build 651 is executed.
This feature is particularly important on Mac OS X, since on this operating system applications are managed as high-level objects (application bundles) that can be handled as regular files, and hence copied and moved to different locations. Now you can copy and move PixInsight application bundles anywhere throughout your filesystem without problems. To make this possible, the application bundles have been renamed on Mac OS X: now we have PixInsight32.app and PixInsight64.app, so an added benefit of this feature is that both applications can be directly copied to the standard /Applications folder (or to any other folder where the user has write access), where they can coexist side-by-side.
- The PixInsight Core application can now handle open events on Mac OS X. PixInsight registers now as an editor for all image file formats it supports with the standard set of file format modules (FITS, TIFF, JPEG, JPEG2000, DSLR raw formats, etc.), plus the file formats owned by the PixInsight paltform: XPSM, PSM (icon files) and XFPC (favorite process collections).
This is an important improvement in the way PixInsight integrates with the Mac OS X desktop. Similar integrations will be implemented for Windows and UNIX/Linux in future versions.
- Improved update repository support. PixInsight repositories can now use metadata specifications to simplify deployment of modules on multiple platforms. The XRI specification will be documented officially following this release.
Happy New Year to everybody!
Re: PixInsight 1.6.9.651
« Reply #1 on: 2010 December 30 11:18:29 »
Thanks Juan and a happy new year to you!
Offline sreilly
« Reply #2 on: 2010 December 30 12:23:57 »
Happy New Year Juan,
Looking at both the software distribution site and using "Update"  I can't see any new versions and PI reports no new updates. Installed version is 01.06.09.0644. Should I be looking elsewhere?
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
« Reply #3 on: 2010 December 30 12:49:51 »
Same here. The updates aren't showing up yet.
« Reply #4 on: 2010 December 30 13:21:31 »
Still 3 files uploading. I think in less than 2 hours I'll update the distribution site and send the notification emails. My Internet connection isn't the fastest one at this side of the Pecos river...  ::)
« Reply #5 on: 2010 December 30 13:23:57 »
I was afraid they went into the wrong folder or something. Thanks for checking. Last night I took my first image in months and I'll be glad to try the new PI on it.
Offline franimede
« Reply #6 on: 2010 December 30 16:16:40 »
Gracias a todo el equipo de trabajo con los mejores deseos de un feliz año nuevo.
« Reply #7 on: 2010 December 30 19:54:31 »
?? both pixinsight32 and 64 (osx here) are not showing any updates available, and it's been several hours since i received the email...  ???
Offline narmad
« Reply #8 on: 2010 December 31 00:02:15 »
Muchas gracias y feliz año 2011
Offline Harry page
« Reply #9 on: 2010 December 31 00:15:33 »
No updates available it says  >:D
Harry
Harry Page
Offline MikeP
« Reply #10 on: 2010 December 31 00:49:15 »
Same here.
An embarrassing number of telescopes
EQ6 Pro
Atik 16HR, SX Lodestar, SX filter wheel, SX OAG
Filters - Baader narrowband, Astronomik LRGB
Windows 7 Pro
Offline Redshift
« Reply #11 on: 2010 December 31 01:21:32 »
If you go to the front page here http://pixinsight.com/  and then click on software distribution that will take you to the download page. I managed to download them at 3.30 am ish this morning. Both the 32 and 64 version running on my Mac.
Nice
Dave
« Reply #12 on: 2010 December 31 01:22:54 »
Hi guys,
No, this is not an update, this is a new version that you must install! ;D
You must go to the software distribution site, log in and download the installation archive(s) for your platform(s):
http://pixinsight.com/dist/
I am sorry; I should have been more explicit in the notification email? ::)
Offline Harry page
« Reply #13 on: 2010 December 31 02:38:47 »
email what email  >:D O:)
Harry
Hi guys,
Harry Page
Offline José Manuel Pérez Redondo
« Reply #14 on: 2010 December 31 04:15:58 »
Thanks!
And Happy New Year
José Manuel (Lleida)
