Author Topic: Run PI from USB drive  (Read 3892 times)
Offline Astrocava
    • Astrocava.com
« on: 2010 December 20 09:42:52 »
I was thinking about make some examples of basic processing for my Astronomy Group using the computer we have. Is it possible to run PI from an USB memory drive?
Have fun!
Sergio
Re: Run PI from USB drive
« Reply #1 on: 2010 December 20 10:06:18 »
I guess it should. But, if you are using windows, I would avoid any problems and just install it there, copy my licence, and then remove everything at the end of the day.
Offline Astrocava
    • Astrocava.com
« Reply #2 on: 2010 December 21 13:00:28 »
That will work, sure.  :) But I'm a bit...lazy.
Sergio
Offline Conor
« Reply #3 on: 2010 December 27 05:55:47 »
You might have more success dumping any registry keys that PI
uses and create a registry script file which will pump them to the
registry and run this from the autorun file in the root directory of
the USB drive. You might want to run a script to delete them though
also, as it's not nice to pollute host machines : ]
Takahashi FSQ 106 EDX III w/ QE Reducer
William Optics 110FLT Apo Triplet
William Optics Megrez 72 Apo Doublet
iOptron CEM60
QSI 583ws & 3nm Ha/OIII/SII filters
SBIG ST-i
Trying to use PixInsight on FreeBSD
Offline Astrocava
    • Astrocava.com
« Reply #4 on: 2010 December 27 12:26:03 »
You give me some to think about: copy and delete the license archive, leaving the program installed. :-)
Have fun!
Sergio
