Author Topic: Pixel rejection preference  (Read 3885 times)
astropixel
  • Guest
« on: 2010 December 02 11:54:45 »
Hi All. Just a quick one. Looking at the images  below, is this a pixel rejection issue. Or, how might I better manage this over exposed areas.
6 x 10 sec, 6 x 20 sec 8 x 120 sec LRGB. plus 2 x 120 sec L.
many thanks
Offline DaveS
    • Dave's Astronomy Pages
Re: Pixel rejection preference
« Reply #1 on: 2010 December 02 12:12:38 »
The only way that I have successfully retained the Trapezium Area of M42, while also capturing the outer areas of the Nebula, is to take both long and short exposures, then combine them using 'Layers' in Photoshop.
The short exposures capture the Trapezium stars without burn-out, and the longer exposures, the outer gas and dust, but with a completely burned out Trapezium area.
When 'layer combined', the inner and outer areas blend nicely, giving a good overall image.
I don't yet know enough about PI, to know whether a similar method of combining long and short exposures is possible, but
hopefully, our resident experts will be able to enlighten us  :)
Dave
8" LX200ACF
William Optics FLT110
NEQ6 Mount
SXVF-H9
SXVR-16
SX Lodestar
DMK21AU04
Baader LRGB and NB filters
DiY Observatory
http://www.progressiveastroimaging.com/davesastronomy/
Offline Harry page
« Reply #2 on: 2010 December 02 13:12:31 »
I can not tell from the images if there is a pixel rejection problem , you would see this from the rejection maps  :D
However there is the HDR script which does construct a image from different exsposures
Loads of info here from lord Juan http://pixinsight.com/forum/index.php?topic=2320.0
Harry
Harry Page
Offline DaveS
« Reply #3 on: 2010 December 02 15:05:16 »
Thanks Harry, that looks interesting  :)
Have now downloaded and installed the 'tool'.
Dave
8" LX200ACF
NEQ6 Mount
SXVF-H9
SXVR-16
SX Lodestar
DMK21AU04
DiY Observatory
astropixel
  • Guest
« Reply #4 on: 2010 December 03 13:17:38 »
Thanks Dave and Harry.
As you can see the results have come a long way - using HDRComposition.
I created separate integrated files for each image subset and then combined with HDRComposition - same for the Luminance channel.
That is - 10 sec R, G and B - integrate, define a linear RGBWorkingSpace and combine with ChannelCombination. Repeat for 20 sec and 120 sec subsets. Combine the 3 RGB images in HDRComposition.
Almost the same for L - integrate each subset 10, 20 and 120 second individually and combine with HDRComposition.
The screenshot rendition is a bit fuzzy, but the improvement is evident.
Offline DaveS
« Reply #5 on: 2010 December 03 14:36:31 »
That is indeed a significant improvement on what you had.  :)
Some further 'tweaking' needed I think, but none the less, a major step in the right direction.
Well done!!
Dave
8" LX200ACF
NEQ6 Mount
SXVF-H9
SXVR-16
SX Lodestar
DMK21AU04
DiY Observatory
Offline vicent_peris
    • http://www.astrofoto.es/
« Reply #6 on: 2010 December 03 15:25:11 »
Hi!
I'm glad to see that the HDRC tool worked so well with your image. :)
Apply HDRWT to this image to flatten the core. Then a bit of color saturation. This is very important to check if it really went fine.
Vicent.
astropixel
  • Guest
« Reply #7 on: 2010 December 04 00:53:17 »
Thanks Vicent and Dave. I followed your suggestions but seem to have removed the four stars in the centre, attempting to reduce the brightness.
I extracted the luminance, applied ATWT to blur the image and reduced with HT, and then subtracted from the LRGB image with PixelMath. That fixed the brightness but removed the central stars.
What do you think - this has been quite a demanding subject and I am learning a lot, but can't quite find my way around resolving the luminosity and retaining detail - where am I going wrong?
Is it that I am attempting to increase the nebulosity, whereas the image really needs more data, and this is over saturating the core?
« Last Edit: 2010 December 04 16:24:36 by astropixel »
astropixel
  • Guest
« Reply #8 on: 2010 December 04 16:16:04 »
10 minutes later.
This time I duplicated the image and reduced its luminosity with HT. Added the clone from the main image and readjusted the brightness with HT.
This is the best that I can do at this stage - where do I need to go from here?
« Last Edit: 2010 December 04 16:37:45 by astropixel »
