Author Topic: PI on Macbook Air  (Read 5028 times)
astropixel
  • Guest
PI on Macbook Air
« on: 2010 November 25 17:02:13 »
Tried PI on an 11" Macbook Air (4GB RAM) this morning. Wasn't able to fully test performance with a stack of images, but it appears to run very well and as fast as my Linux installation which has only 2GB memory.
As you know, the Macbook Air is a solid state device. Just wondering if anyone has any thoughts, cautions, warnings, reservations etc.
Offline Philip de Louraille
Re: PI on Macbook Air
« Reply #1 on: 2010 November 25 17:52:06 »
I do, I do. But I need to test them. Please send your MacBook Air to me first. I'll let you know if my concerns warrant me sending it back to you.  >:D
Philip de Louraille
astropixel
  • Guest
« Reply #2 on: 2010 November 25 20:38:01 »
Only wish it were mine :'(
I see that they have 2GB RAM. The owner told me 4GB. So performance is pretty good.
« Last Edit: 2010 November 26 01:13:48 by astropixel »
Offline papaf
« Reply #3 on: 2010 November 26 01:58:28 »
SSDs lifespan is dictated by write access. In read only mode, they're virtually unbreakable. Write operation are numbered, though, and some manufacturers even specify how many writes you can do before breaking it.
Granted, we're not talking about tens, but rather thousands of writes.
Obviously, PI makes great use of the HD, with every image getting rewritten everytime it's aligned and/or calibrated. So that would be my first concern.
« Reply #4 on: 2010 November 26 02:39:16 »
I have an SSD in one of my laptops. It has been working without any flaws for the last 6 months, almost 24/7. We had much more trouble with ordinary laptop harddisks in the past. So far, the SSDs have been a blessing for the IT department...
Offline jmtanous
« Reply #5 on: 2010 November 26 08:50:36 »
I have a Macbook pro with a 128 solid state disk (SSD). This laptop has been my workhorse for the last year without any single issue. The solid state disk is very fast compared to spinning hard drives.
The number of writes is limited but (big but), it is more likely that the laptop will become obsolete before the SSD start failing.
Jose
astropixel
  • Guest
« Reply #6 on: 2010 November 26 16:59:02 »
4GB RAM would be ideal. I think I'll wait and squeeze a bit more out of my old laptop.
Offline Sean Houghton
    • Cerebiggum
« Reply #7 on: 2010 November 26 23:06:10 »
We use a 6 TB SSD storage accelerator at work to speed up our build farm.  This thing rips through massive amounts of writes every day.  We haven't had a failure yet and it has had an incredible effect on speed.  I think the cell limits are up to about 100,000+ writes now - which is beyond what most people could do with normal usage.
I have been considering switching my old MacBook Pro to SSD but it would be tough to go from 500 to 128 GB  :'(
Sean
Carlsbad, CA
cerebiggum.com
Offline papaf
« Reply #8 on: 2010 November 29 04:23:37 »
Well, not every ssd is the same. If you use a 6TB (!!!!!!!!!) ssd solution, it's just not going to be the same technology used in a mac book, or in any other "cheaply" priced ssd.
So numbers coming from a very professional (and I bet, very expensive) case shouldn't be applied to all the technology all together.
« Reply #9 on: 2010 November 29 11:39:33 »
yeah, i have to say that i had a very bad experience with a corsair X256 SSD in my macbook pro. it was supposed to be a decent SSD, using a good controller. but it died twice and then i just gave up with RMAs. at this point i'd probably only buy an intel SSD if i wanted one.
astropixel
  • Guest
« Reply #10 on: 2010 December 04 03:59:55 »
I don't like buying technology for the sake of it. But the usefulness, portability of the Macbook Air is very attractive. At the moment I run lean fast Linux distributions on all but forgotten technology - I was lucky to pick up a Lenovo TP which is my image processing  machine. AUD 80 for an extra 2GB memory, as opposed to around 13-1500 for a MBA.
