Author Topic: HaLRGB  (Read 4731 times)
Offline Nigel Ball
    • Astrophotography by Nigel
HaLRGB
« on: 2010 November 15 01:28:59 »
Morning all
I've already posted an image of the Horsehead nebula in the Gallery section
Last night I collect some Ha data to try and bring out the faint nebulosity.
My question is how do I add this in. Ha is in the red region so do I combine with the red channel? or use the Ha data as Luminance? If so some guide on how to 'add' channel data together would also be appreciated. I haven't used PixelMath yet and I assuming it is this tool I'll need to become familiar with.
I appreciate this is a fairly fundamental question but it is sometimes the basic stuff that holds us up
Thanks in advance
Nigel
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Offline Philip de Louraille
Re: HaLRGB
« Reply #1 on: 2010 November 15 06:17:44 »
Hi Nigel,
That topic was already discussed here:
http://pixinsight.com/forum/index.php?topic=2298  and an older discusion is here as well
http://pixinsight.com/forum/index.php?topic=562.0
In the first post, Jack explains how to create two new master channels which are subsets of the Red master channel and the Ha master channel. I'm explaining what I have read because it is not clear (sorry Jack!)
Suffice to say that he shot with 4 filters: Ha, R, G, and B.  (notice no separate L.)
So say your narrow filter bandpass is 5nm
You create a new red channel where you remove the contribution from Ha
new_red = m_red - m_Ha
new_Ha = m_Ha - 0.05 * new_red
Finally a mix
red_channel = 0.6 * new_Ha + 0.4 * new_red, and you can play with the 0.6 and 0.4 coefficients.
Now get you color image with assembling
red_channel, m_green and m_blue
Well! I just found a new tutorial from Vicent Peris here about this
http://pixinsight.com/tutorials/narrowband/theory/en.html
There is also a tutorial about PixelMath but do not read the whole thing, it will make your head explode.
It is a complete tutorial with examples.
Skip to the "Merging Images" part. Near the end.
Philip de Louraille
Offline Nigel Ball
Re: HaLRGB
« Reply #2 on: 2010 November 15 06:57:22 »
Thanks Philip
I always forget to search the forum  :-[
Nigel
Nigel Ball
www.nigelaball.com
Offline Emanuele
Re: HaLRGB
« Reply #3 on: 2010 November 15 11:25:41 »
maybe I am missing something but to do the initial  M_Red - M_ha , do we need the images to be linear ?
Re: HaLRGB
« Reply #4 on: 2010 November 15 11:49:10 »
Yes. We are dealing with the Masters, just out of integrations.
Philip de Louraille
Offline Emanuele
Re: HaLRGB
« Reply #5 on: 2010 November 15 15:01:10 »
Thanks Pde.
I just tried this method on an image I am working on with Ha, R, G, B.
The problem that I have with this method is that I can't really squeeze every bit of information from the Ha channel, since it is blended with the Red one and combined right away with the G, and B channels.
By doing an Ha-RGB combine using the LRGBCombination process, and treating the Ha data as the L, one could squeeze every bit of data there is in the Ha frame.
The drawback is that the result using LRGB (Ha as L) is a pink image.
Any way to avoid that?
E.
« Last Edit: 2010 November 15 15:17:59 by Emanuele »
