Author Topic: Applying DBE  (Read 3273 times)
Offline Nigel Ball
    • Astrophotography by Nigel
Applying DBE
« on: 2010 November 14 09:49:09 »
Hi all
I've been processing an LRGB image of the Horsehead nebula and found I had to apply DBE twice. I spent a long time adding samples one the initial pass but couldnt get rid of the Green gradient. Hence, the second application.
The image appears to be okay so my question is 'Are there any issues with applying DBE twice?'
Nigel
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Offline Harry page
Re: Applying DBE
« Reply #1 on: 2010 November 14 09:56:45 »
No I do this many times , If the error is too large do it twice or three times ,  I sometimes lower the tolerance on the second run so as not to take in any
background information or you try increase the tolerance on the first run ( i have used from 0.05 to 3 )
regards harry
Harry Page
Offline RBA
    • DeepSkyColors
Re: Applying DBE
« Reply #2 on: 2010 November 14 16:52:38 »
There's not a problem in applying DBE more than once.
However... I would suggest to spend on the first DBE as long as possible, by adjusting sample placement and parameter adjustments.
To me - and this is a very personal approach (feel free to criticize it, it may help me improve!) - the reasoning is simple and I've said it several times already...
Whether you're trying to fix a vignetting (check your flat acquisition/calibration!) or a gradient, it is in the first DBE when you can get a good picture of a background model that looks like such gradient or vignetting.
Once you're correcting over an image that has already been DBE'd, your model will no longer look like the gradient/vignetting you're trying to remove, so you're increasing the guesswork when it comes to evaluate the results (the results are not only the corrected image, but the image AND the background model).
I always check my background model BEFORE I check the corrected image. If the background model does NOT look like the gradient I'm trying to correct (ie. it has lumps or imprecisions that can not be the way a gradient looks like) then I'm either "oversampling" (putting too many samples), putting samples in the "wrong" place, or my parameters are too relaxed/coarse. If the model looks ok, then I check the corrected image. If it doesn't, I also check the corrected image but most of the time, if not always, I undo and try to improve the model... By following this method, I rarely need a second DBE.
Now... Usually, a second or third DBE should address problems that the first couldn't solve, and these, ideally, should be very easy to spot/identify (so you know how your next model should look like) - for example, your gradient may be very gradual, but it starts very strongly, so maybe the smoothing factor/etc used in the first pass worked well in modeling most of the gradient but not the "abrupt" area, etc. Personally, going for more than 2 DBEs, with a few exceptions (like the one I just mentioned), I think it's either overdoing it or a somewhat careless use of the DBE in the first pass.
Another of such exceptions would be I guess applying DBE over a RGB image. Here, each channel is going to have a life of its own, so identifying the shape of the background model is often wishful thinking, as it's a mix of three different models - unless you take the time to break the source image and the model into the three RGB channels, and examine one by one, but then, why not just apply DBE on each channel independently? So when applying DBE over a tricolor image, you may simply examine the results (the model too but not as crucial, depending on the case), see if the color is homogeneous across the entire image, and if it isn't, run the DBE again, etc. Does this make sense?
Once again, this is my very personal philosophy about using DBE. It works well for me (well, most of the time  :angel: ) , but like I said, I'm open to other, better ways to use it...
Offline RBA
    • DeepSkyColors
Re: Applying DBE
« Reply #3 on: 2010 November 14 17:00:24 »
One more thing...
I think many people tend to put too many samples, thinking this helps modeling a better gardient or whatever. But... You're modeling a gradient! Gradients are usually of a smooth gradual nature (usually - not always). By placing too many samples you're risking "sampling" valid signal. Of course this will depend on many things, not one size fits them all, ever, but as a rule, I look for where the background is in my image ("screen stretched" of course), I place my samples there, and I often start with just a few, maybe 10-15 samples or so... Then I adjust them (add/remove/relocate samples) depending on what the background model "tells" me.
Again, this seems to work for me.
Offline mmirot
Re: Applying DBE
« Reply #4 on: 2010 November 14 19:49:25 »
I find avoiding all stars in the sample a very helpful 1st step. I also splitting the image into RGB is often easier.  As you point out there are often three separate gradients to model.
Max
