Author Topic: Need RGB fits of Rossetta Nebula  (Read 4465 times)
Offline Silvercup
« on: 2010 September 22 03:37:43 »
Hi:
I have resumed developing of Multichannel Combination script, I have written the Interface. So I need some R, G and B fits integration of the Rossetta Nebula to mix with my Narrowband data.
Could somebody share RGB fits?
Thanks. Silvercup.
Hola:
Si alguien tiene R-G-B fits de la Roseta y me los puede pasar para desarrollar el script Multichannel Combination se lo agradecería.
Saludos. Silvercup.
Offline Jack Harvey
Re: Need RGB fits of Rossetta Nebula
« Reply #1 on: 2010 September 22 07:32:57 »
Don't have Rossette but have Helix masters ready to combine in R,G,B, Ha and OIII?
Jack Harvey, PTeam Member
Offline Nigel Ball
    • Astrophotography by Nigel
« Reply #2 on: 2010 September 22 10:35:41 »
I have some DSLR FITS of the Rosette which you could slpit into RGB?
Nigel
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Offline Silvercup
« Reply #3 on: 2010 September 23 01:27:28 »
Thanks guys:
I would like to try both.
Nigel could you upload Rosette master RGB to Harry's server if he don't mind?
Jack where can I download Helix data?
Silvercup.
Offline Nigel Ball
« Reply #4 on: 2010 September 23 02:12:19 »
Silvercup
I have the file ready - is Harry okay with this?
Nigel
Nigel Ball
www.nigelaball.com
Offline Jack Harvey
« Reply #5 on: 2010 September 23 06:30:19 »
How about via DropBox.  If you do not use it you can install it for free.  Sent the masters in a shared folder to you that way.
Offline Silvercup
« Reply #6 on: 2010 September 23 07:17:13 »
Thanks Jack. Downloading...
Interesting application.
Best. Silvercup
Offline mmirot
« Reply #7 on: 2010 September 23 18:27:48 »
I just found this for on line storage.  19USD per year. What do you guys think?
I think it might be time to start buying online storage.
http://www.onlinestoragesolution.com/
Max
