Author Topic: Just Checking Out Image Calibration  (Read 4158 times)
Offline sreilly
« on: 2010 September 12 14:42:43 »
I just went through the image calibration process and only hitch I had was on the Dark Frame settings. I had the Optimize box checked and when I checked the images they appeared to not have been dark subtracted even though the Calibrate box was checked. Running the sequence a second time and all went as expected after unchecking the Optimize box. As my camera does bloom on bright stars I don't really see a need to use this process as I still need to go back into MaxImDl/CCD and do bloom removal. I use MaxIm as it is my software of choice (and need for ACP) for acquiring data. I usually do the image calibration in MaxIM and then the bloom repair before saving and working on in PI. Does PI have a better calibration routine? I can't see how if I'm using the same master frames that were made in MaxIm. Also, I don't see a routine for creating master calibration frames in PI. I imagine it can be done, any suggestions as to how?
I also usually remove hot pixels in MaxIm before saving. What process would be the equivalent in PI?
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Re: Just Checking Out Image Calibration
« Reply #1 on: 2010 September 12 16:38:46 »
Steve, there is a badpixel process, give that a try. I think it's a bit cumbersome so I may port my fixfits utility to PI which does it automatically.
http://www.tungstentech.com/Software/FixFITS/tabid/78/Default.aspx
Offline sreilly
« Reply #2 on: 2010 September 14 17:03:10 »
Hello Sander,
I gave you fixfits a try and not sure I'm doing it properly. I have the folder of images on my terabyte drive which is drive J and the Volume Name is MasterImage. The image folder is All-NGC7331 and the sub folder is PI. I am using Run, CMD and then typing J:\All-NGC7331\PI>fixfits -a -fc and get the error 'J:\All-NGC7331\PI' is not recognized as an internal or external command, operable program or batch file. I did edit the path as C:\bin as I did extract the files to the new folder c:/bin. I also did this on the J drive and added that path as well just in case. Adding in the volume name,  J:\MasterImage\All-NGC7331\PI>fixfits -a -fc gets me "System can not find the path specified. I suspect I'm doing something stupid? Care to suggest my error?
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline sreilly
« Reply #3 on: 2010 September 14 17:13:25 »
I should mention that this is a Windows 7 64 bit system if that makes a difference.
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
« Reply #4 on: 2010 September 14 17:19:08 »
The command is just 'fixfits'. Nothing prefixes it. What happens when you just type 'fixfits' on a command prompt?
Offline sreilly
« Reply #5 on: 2010 September 14 17:30:02 »
I get version info and instructions
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
« Reply #6 on: 2010 September 14 17:31:08 »
Great! Then you know what you did wrong before.
Offline sreilly
« Reply #7 on: 2010 September 14 17:45:07 »
Duh...It's been a while since I used any command line stuff. OK, I see the error of my ways. I'll need to go back and just calibrate and de-bloom to see the real power behind this process.
Thanks for the patience!
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
« Reply #8 on: 2010 September 14 17:47:23 »
