Author Topic: second installation  (Read 3193 times)
Offline DarrenS
second installation
« on: 2010 September 11 09:05:00 »
new pixinsight user here with a tech support question
I have a multiboot enviroment with using windows installations on partitions C: and D:, but I cannot get pixinsight to install on the D: partition?
Installs and runs fine on C: (c:\PCL) but cannot get the installtion to run on d:
Tried both D:PCL & D:\Program Files, also copied the licence from C: to D:
attached is a screen shot of the error.
any ideas?
btw I tried the 45day trial, hummed and ahhed(sp) over buying for a few days using cs3 etc then started to get withdrawl symptoms, quality product well done.
Darren
Re: second installation
« Reply #1 on: 2010 September 11 10:01:40 »
Hi Darren,
Welcome to PixInsight Forum.
The solution to this problem is installing a redistributable package from Microsoft:
For 32-bit Windows versions:
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
http://www.microsoft.com/downloads/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
For 64-bit Windows versions:
Microsoft Visual C++ 2008 SP1 Redistributable Package (x64)
http://www.microsoft.com/downloads/details.aspx?familyid=BA9257CA-337F-4B40-8C14-157CFDFFEE4E&displaylang=en
Besides redistributables, you should keep your Windows installations up-to-date with the latest service packs available.
Let me know if this works.
Offline DarrenS
« Reply #2 on: 2010 September 11 10:50:49 »
Now working  :)
thank you Juan
Offline sreilly
« Reply #3 on: 2010 September 11 12:40:03 »
I know this is basic but are you booting into each respective OS and installing or trying from just one? I've had multi boot (3) OS systems and if you are new to them it takes some getting use to installing from each OS.
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline sreilly
« Reply #4 on: 2010 September 11 14:52:11 »
I must be geeting too tired. I could have sworn Darren's secod post was it wasn't working :-[
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
