Author Topic: New Script: 33 Common Convolution Matrices  (Read 8848 times)
Offline Christoph Puetz
    • Fotos
« on: 2010 September 01 10:26:09 »
Dear PI Users,
this is my first PJSR script. It features a collection of 33 common convolution matrices, that can be selected by Menu-Entry and
applied to your picture(s).
It can easily be extended and I plan to do so in future, so check for updates regularly, please.
After installation the Script can be called by Menu->Scripts->Common Convolution Matrices.
Hope it may be useful for you.
Kind regards,
Christoph
Kind regards,
      Christoph
Canon EOS 500d,
PixInsight, PHD-Guiding
private URL: www.ccdsky.eu
Re: New Script: 33 Common Convolution Matrices
« Reply #1 on: 2010 September 01 10:43:18 »
Good job. One possible future addition could be to draw the convolution kernel, or to display the coefficients. :) Keep the good work comming
PS: Thanks for the citation ;)
« Reply #2 on: 2010 September 01 11:18:24 »
Hi Christoph,
Welcome to PixInsight development, and congratulations on a nice script!
The script works nicely for low-pass filters, but convolution with a high-pass filter requires fixing out-of-range values.
For example, if you convolve with a sharpening filter such as:
 0  -1   0
-1  +6  -1
 0  -1   0
there can be values outside the [0,1] range in the convolved result. This happens because the convolution routine applies a unit filter weight when there are one or more negative filter coefficients.
There are two ways of fixing out-of-range values: truncation and rescaling. Truncation to [0,1] is the standard procedure; it causes some data loss due to ringing, but preserves the overall brightness of the convolved image. Rescaling keeps all the data at the cost of a loss of dynamics, which is a nonstandard procedure (useful in some contexts, but not in the context of general image filtering).
So I think you should add a call to Image.truncate() in line #399 of your script, just after calling Image.convolve():
console.flush();
        img.convolve( conv_matrix );
        img.truncate();
vw.endProcess();
Hope this helps.
« Reply #3 on: 2010 September 01 11:34:15 »
Long live out of range values!!!! Don't opress them!!!!
:D
Jokes apart, for a high pass filter like that one, this truncation or rescalation makes a lot of sence, while for other operators, like the edge detectors (gradients), or laplacians, out of range values have a very meaningful meaning, that should not be changed.
This reminds me that we have to deeply discuss this topic, on future development (and btw, I can't see why complex images cannot be managed by the UI).
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
« Reply #4 on: 2010 September 01 16:36:11 »
Nice script Christoph, thanks for your work!  :D
A small suggestion that might be useful for the future: when there is only one value to compare, instead of using many IF, you can use a single SWITCH. For example:
switch( index ) {
  case 1:
    conv_matrix = [ 1, 1, 1,
                    1, 1, 1,
                    1, 1, 1 ];
  break;
  case 2:
                    1, 2, 1,
                    1, 1, 1 ];
  break;
The result is the same, of course.
Best regards,
Enzo.
    • Fotos
Re: New Script: 33 Common Convolution Matrices, Version 1.2
« Reply #5 on: 2010 September 02 09:51:53 »
Hi, uploaded Version 1.2 - added img.truncate() as supposed by Juan.
Further extensions coming soon.
Thanks to all !
Christoph
Kind regards,
      Christoph
Canon EOS 500d,
« Reply #6 on: 2010 September 02 11:43:07 »
Keep up the good work Christoph,
And don't be too concerned if you don't see too many 'downloads' - a lot of folk will pick and choose what they need from these kind of code developments. For example, I have not YET downloaded your script, but I AM keeping a close eye on how it develops. Personally, I will 'jump in' as and when I can devote some time to actually 'playing' with your script - but the whole concept is definitely one of interest to me.
