Nigel,
Maybe my brain is fried from having just driven a 750-mile round trip for a two-hour business meeting yesterday (
), but I cannot see how 'Drizzle Combine' is any different from 'normal combine'.
Surely, the point of 'Drizzle' actually takes place at the 'capture' stage, not at the point of 'combination'?
After all, no matter how you set about acquiring the data, at some point you have to pick a reference image (real, or synthesised) and use that to align all the other images in your data set. You can't really alter that fact. After all, any image that is not 'perfectly aligned' would surely then simply be contributing TO the 'noise element' of the resultant image. In other words (again, no matter 'how' the original images were acquired) you MUST strive for 'perfection' in alignement of all images that will subsequently be stacked.
So, StarAlignment (or equivalent) solves that requirement - perfection of alignement. And then ImageIntegration sorts out (and very well, I might add) the need to 'stack' all the images thereafter.
In my mind, 'Drizzle' - a process applied during the 'capture' stage - serves to either :-
1.) Increase the overall pixel count of a final image - by effectively creating a 'mini-mosaic' of superimposed images, created by allowing the scope to 'wander around' some central reference point, acquiring as many images as possible to allow a decent mosaic to be recosntructed
2.) Decrease the 'noise' impact of 'chip defects' (including dust effects) by ensuring that all images place the key alignment points (such as stars, etc.) at slightly different locations on the CCD, for every image captured - which, as a result of subsequent 'averaging' of the then aligned images, causes this 'noise' to be eliminated because it now has a 'random' spatial relationship to the actual photonic data captured (random noise in 'n' images can, theoretically, be reduced by a factor of '
1/
n-squared')
3.) Increase the 'perceived pixel resolution' of a given CCD sensor due to the effects of sub-pixel-sampling required in the re-alignment process, when the images have been acquired with a random dither applied between images - for a far clearer explanation, have a look at the two articles by Stephen Hamilton at
http://www.hamiltonastronomy.com/ASTRO_ARTICLES/DSI_Drizzle_Part_1.pdf and
http://www.hamiltonastronomy.com/ASTRO_ARTICLES/DSI_Drizzle_Part_2.pdf (although these are related to the Meade DSI and Meade's Envisage software, they explain things far more clearly that I could ever hope to!!)
So, have I missed the point of your question? I don't really see the need for a "Drizzle Combine" add-on. Can someone else comment?
