Thanks Niall for your corrections. So unless somebody wants to argue something this is the full license text that should appear on all source files pertaining to the standard open-source modules:
This file is part of the standard <MODULE_NAME> PixInsight module.
Copyright (c) 2003-2010, Pleiades Astrophoto S.L. All Rights Reserved.
Redistribution and use in both source and binary forms, with or without
modification, is permitted provided that the following conditions are met:
1. All redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
2. All redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
3. Neither the name of Pleiades Astrophoto, nor the names of its
contributors, may be used to endorse or promote products derived from
this software without specific prior written permission from Pleiades
Astrophoto. For written permission, please contact info@pixinsight.com.
4. All products derived from this software, in any form whatsoever, must
retain the following acknowledgment:
"This product is based on software from the PixInsight project, developed by
Pleiades Astrophoto and contributors. The PixInsight project is available at
<http://pixinsight.com/>."
THIS SOFTWARE IS PROVIDED BY PLEIADES ASTROPHOTO AND ITS CONTRIBUTORS
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL PLEIADES ASTROPHOTO OR ITS
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, BUSINESS
INTERRUPTION; PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; AND LOSS OF USE,
DATA OR PROFITS) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
The open-source modules are (so far): BMP, FITS, JPEG, JPEG2000, TIFF, Geometry, Global, GREYCstoration, Image, ImageCalibration, IntensityTransformations, Sandbox and StarGenerator. The Sandbox module will be put in the public domain.
All PCL and PJSR header files will include the same disclaimer and the corresponding copyright notices. Applying the full license to PCL and PJSR doesn't make sense because they are (still) closed-source products.
