Author Topic: PCL: on startup my dialog is sometimes much too wide  (Read 6292 times)
I've been struggling with an annoying problem with one of my processes.
- use process
- cancel process (it's a dynamic one)
- open process again
- now dialog is very wide, extends way to the right
It seems process location and size is stored somewhere and I'm not doing the right thing to restore it on load. What could be the cause?
Re: PCL: on startup my dialog is sometimes much too wide
« Reply #1 on: 2010 July 29 16:26:56 »
Hi Sander,
I'd need to take a look at your code to help you. It might be an issue with Sizer. The geometry of a ProcessInterface is always stored in the core settings file unless you call ProcessInterface::DisableAutoSaveGeometry() explicitly from your code.
« Reply #2 on: 2010 July 29 17:05:25 »
Hi Juan,
I sent a zip with the sources your way.
« Reply #3 on: 2010 July 29 17:15:18 »
Thanks Sander. I'll take a look and will post here.
« Reply #4 on: 2010 July 31 05:25:57 »
Hi Sander,
I've already sent your code with the pertinent revisions. The tricky bit that you were missing is a call to AdjustToContents() at the end of your GUIData constructor. Always call this member function after having populated your interface's main sizer.
Excellent and very useful tool you're cooking. Hope to see it published soon ;)
« Reply #5 on: 2010 July 31 06:51:13 »
Thanks Juan, got your email :)
