Author Topic: Processing console  (Read 5786 times)
Offline RobF2
  • Rob
    • Rob's Astropics
Processing console
« on: 2010 June 06 05:00:19 »
Do I have to see the processing console every time I run a process, then close it to get it out of the way?
1.   Surely there is some setting so I never see/appreciate all the workings going on?
2.   I'm sure it used to spring back out of the way by itself?
R
Rob's Astropics
Offline vicent_peris
    • http://www.astrofoto.es/
Re: Processing console
« Reply #1 on: 2010 June 06 06:23:53 »
look at the icons at the top right of the console. You must have checked an icon that's like a square. Uncheck it.
Regards,V.
Offline dhalliday
    • on Flickr
« Reply #2 on: 2010 June 06 07:49:18 »
"An icon that's like a square"...
Which one...?they are are "like a square"....
That has been annoying the heck out of me too...
I am trying to look (quickly) at the "before and after"....but all I can see is this dumb "processing" box...
Only been 1 year now... >:D
Dave
Dave Halliday
SSAG/EQ6
CGE Pro
SBIG ST2K,ST10XME
« Reply #3 on: 2010 June 06 11:38:12 »
Don't close the Processing Console window. If you close it, it will be automatically re-opened the next time you execute a process. This is because the PC window is used by PixInsight to provide feedback and progress information about the ongoing processes. The PC is also the only way to stop a process from the GUI (the Pause/Abort button). In other words, the PC window is a necessary component of PixInsight's graphical interface; don't try to fight against it --it is there to help you, not to annoy you.
You normally don't need to close or hide the PC window manually because it is automatically hidden when a process finishes (unless you launch the process from the console, and if the PC window is not in stick state --the square button that Vicent refers to-- or floated as a top-level window).
All auto-hide windows (Processing Console, Process Explorer, etc.) are automatically hidden by simply making a click anywhere on the workspace (including image windows).
If you think the PC window is being shown too often, you can control the time elapsed until the PC window is automatically shown with preferences:
- From the main menu, select Edit > Global Preferences.
- Select the Miscellaneous Process Settings section on the left panel.
- Enter the desired time in milliseconds for Console window delay. The default value is 750 ms. Try with 1200 or 1500 ms for example, if you want to see the console appearing only for "heavy" processes. Also read the tool tip information that pops up when you place the mouse cursor on this item.
- Click the circular blue button (or press F6) to apply the process globally.
Hope this helps.
« Reply #4 on: 2010 June 06 12:23:33 »
You should try processes on previews first. Just make a preview of the full size of the image. With Ctrl+Shift+Z you may quickly undo/redo the preview's state. The console is not shown between those changes.
« Reply #5 on: 2010 June 06 14:44:06 »
I have found a 'luxurious way' to deal with the Console window in PI.
'Float' the console as a window in its own right (you can do this now in v1.6.0), and then drag it away to a secondary monitor, then re-size it to full screen on that monitor.
That way it is ALWAYS there - and you can see what is happening as PI rattles through all of its processes.
Now I don't ever want to use PI with the Console hidden !! (OK, so you need a multi-monitor setup, but PI gave me just the excuse I needed to justify the expense ::))
Offline yock1960
« Reply #6 on: 2010 June 06 14:44:57 »
You used to be able to move the Processing Explorer tab over to the right hand side and leave an open space at the top left. That way if your mouse wandered over that area on your way to the undo/redo icons, you wouldn't pop it open. now if you move any of the Explorer tabs, the others move up. I like the old behavior better. I haven't been able to figure out how to leave an open space at the top.
Offline RobF2
  • Rob
    • Rob's Astropics
« Reply #7 on: 2010 June 07 03:37:39 »
I was too embarassed to ask this one previously, but realised last night how much it was bugging me.  I had turned autohide off.  I think a combination of bottom-left and knocking the delay time up to a few seconds will take care of much of this for me.  I'd only want to interupt a process if its been going more than a few seconds anyway, and if I want to see the textual info over the image views I can always wave the mouse.
Many thanks everyone!
Rob's Astropics
