Author Topic: DSLR RAW (CR2) read in ImageIntegration  (Read 4697 times)
Offline moscow
« on: 2010 April 18 10:42:08 »
Hi.
Alittle improve please, I think its easy... :) If u can, sure.
I now use Image Calibration tool, look great. Then I prepare master bias / dark, i use Image Integration, but must use Batch Format Convertor script before :(
Thanks and WBR, Oleg
Re: DSLR RAW (CR2) read in ImageIntegration
« Reply #1 on: 2010 April 18 10:55:44 »
Not that easy :D The reason is that so far the fits format is the only one that allows incremental reading (you don't have to read the whole file to get the pixel values). So, if we want to add new image formats to a integration algorithm, it should be re-engineered completely, and it would be less efficient than it is right now.
Offline moscow
« Reply #2 on: 2010 April 18 23:16:01 »
Sure, Carlos, not realy needed, if it so difficult, no problem!
