Author Topic: Problem between PI and Photoshop  (Read 4671 times)
Offline thierry31380
« on: 2010 April 03 06:32:42 »
Hello,
i m trying PI and i love it s really a powerfull software and i will buy it sooner
I encounter a problem between PI and PS CS4
after processing a picture in PI, i save it in Tiff 32 bits, if i open it with PS the picture is very much bright than in PI, i have to adjust curves and levels
is there a parameter to preserve adjustments in both software?
Sorry for my poor english, hoping you understand what i mean
Regards
Thierry
« Last Edit: 2010 April 03 06:38:24 by thierry31380 »
Offline mmirot
Re: Problem between PI and Photoshop
« Reply #1 on: 2010 April 03 09:51:27 »
I always use the 16 bits TIFF mainly because not everything works in 32 bit.
Perhaps, You should re-post in the other forum ===this is a possible bug?
« Reply #2 on: 2010 April 03 10:58:21 »
Hi Thierry,
Welcome to PixInsight Forum! And thanks for the nice words ;)
This is not a bug. It is simply that PixInsight and the other application use different numeric ranges to represent pixel sample values in floating point format. PixInsight uses the normalized [0,1] range where 0=black and 1=white. The other application I don't know.
In PixInsight, yes. You can define the default input range for floating point FITS and TIFF images:
- Open the Format Explorer window.
- Double click on the FITS (or TIFF) format item, on the left column.
- Enter the appropriate lower and upper range values in the corresponding fields of "Default Floating Point Input Range".
- Click the OK button.
Note that this only changes the way PixInsight reads floating point images. Floating point images written by PixInsight will always be normalized to the [0,1] range.
In the other application I don't know if you can specify a default input range for floating point images.
« Reply #3 on: 2010 April 04 03:00:41 »
Thanks guys for reply,
mmirot, you are right, saving in 16 bits there's no more problem, levels are same.
Juan: i don't know where is the setting in PS, but now that i know that is working in 16bits i have  no more the problem
regards
Thierry
