Harry
Thanks again...
Looking at the two...with my untrained eye its hard to see a HUGE difference...but I think there is...
Nevertheless I have seen enough "L" for a while...
I have had a week or so to "think it over"....
And have SUCCEEDED in doing BOTH combinations...
So..goals met..
I will try just LONGER RGB subs...hopefully tonite,on M1...!!
(IF your alarm goes off at 2 AM,its minus 12 out and you STILL get up and go out...you are motivated
I don't know about your sky,but I can only expose about 4-5 mins in Lum...maybe 10 in RGB..
My only worry is that the NOISE in RGB subs is going to be worse,...
Exp times are longer,and signal is lower...(!!)
Harry,again,I owe you...!
Dave
