Author Topic: 1.8.8-4 cosmetic correction bug  (Read 9643 times)
« on: 2020 February 27 20:50:22 »
on large images with a mask applied, CosmeticCorrection throws an "incompatible mask geometry" dialog box and then locks the view being executed on forever, as well as keeping the RT preview busy forever.
steps to reproduce:
using MacOSX PI 1.8.8-4,
NewImage, size of 5976x3840, 3 channels
extract L from this image
mask the image with the L
open CosmeticCorrection and select "Auto detect" with "Hot Sigma" of 3.0
open RT preview. the machine will think hard for a while and then exhibit the behavior described above.
Offline John_Gill
Re: 1.8.8-4 cosmetic correction bug
« Reply #1 on: 2020 February 28 02:19:03 »
Hi pfile,
I have never used a mask for CosmeticCorrection, can you explain why you use a mask.
space is not black
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
« Reply #2 on: 2020 February 28 08:17:52 »
it was a mistake, the mask happened to be applied to the image.
regardless it pretty much locked up PI so it should be fixed
