Author Topic: SubframeSelection question re: SNR weight  (Read 14193 times)
Offline MineralMike
« on: 2020 February 22 07:41:53 »
I very much like the new SubframeSelector process, and have a question about the term "SNR weight."
Why is the word "weight" present? How does "SNR weight" differ from plain old "SNR?"
Just wondering.... Thanks.
--- mike
Re: SubframeSelection question re: SNR weight
« Reply #1 on: 2020 February 22 07:47:01 »
i believe this doc refers to the script, but very likely the meaning of the keyword is the same between the two versions of SFS:
https://pixinsight.com/doc/scripts/SubframeSelector/SubframeSelector.html#subframe_property_SNRWeight
Offline aworonow
    • Faint Light Photography
« Reply #2 on: 2020 February 22 08:26:09 »
Unless things have changed since Juan wrote (https://pixinsight.com/forum/index.php?topic=1500.msg8110#msg8110), "We cannot estimate the SNR directly because the noise introduces uncertainty in the data," in 2009, and it maybe be so, I would not rely too much of SNR for weighting subframes.
Be very much interested in knowing if Juan's assessment is still valid!!! I use a combination of other subframe parameters, including #stars, star eccentricity, and FWHM.
Offline MineralMike
« Reply #3 on: 2020 February 22 10:47:10 »
As a PI newbie, I'm following instructions from Keller's book to use the sub with the highest SNR weight as the reference when integrating subs.
Is there a better choice? What should I use instead?
Thanks.
--- Mike
« Reply #4 on: 2020 February 22 11:02:57 »
i uh... dont know what to say about that advice... the default method for subframe weighting in ImageIntegration is indeed SNR weight.
https://pixinsight.com/doc/tools/ImageIntegration/ImageIntegration.html#description_002
even juan's post linked above says that you can estimate SNR improvement between two images.
and per that post, as long as you can properly scale/normalize two images, you can indeed compare the SNR between the two images. and that's what ImageIntegration does in the absence of any externally generated weighting keywords.
Offline MineralMike
« Reply #5 on: 2020 February 22 19:47:46 »
Thanks. In the SubframeSelector, should I sort the list of subs in descending or ascending order on SNR Weight to choose which sub to use as the reference in imageintegration?
IOW, is a high SNR Weight better than a low SNR weight? I know little about statistics, so I'm searching for simple guidelines.
Thank you.
--- Mike
« Reply #6 on: 2020 February 22 22:02:20 »
well i think larger SNRWeights are better but since i don't regularly use BPP or WBPP i am just going by what i think the documentation means. maybe someone else can say more definitively.
Offline aworonow
« Reply #7 on: 2020 February 23 08:33:57 »
I agree that SNRWeights appear to be more in tune with what one would want from subframes than other noise measures.
