Author Topic: MureDenoise Missing in Version 1.8.8-4  (Read 1834 times)
Offline andrewbarton
« on: 2020 February 01 17:13:51 »
I was just getting ready to use MureDenoise and find it is missing after a recent update.
I am running Version 1.8.8-4 on the Mac.
Looking in the /Applications/PixInsight/src/scripts/mschuster/MureDenoise I see this directory is empty. /Applications/PixInsight/src/scripts/mschuster/MureDenoiseDetectorSettings/ is empty as well.
Other mschuster scripts appear to be present.
Andrew
Re: MureDenoise Missing in Version 1.8.8-4
« Reply #1 on: 2020 February 02 11:54:41 »
I was able to get MureDenoise and MureDenoiseDetectorSettings back by reinstalling PixInsight from the latest download. After doing this, I could see that the Mure Denoise scripts were back in the src/scripts/mschuster directory. But I was still missing the Script -> Noise Reduction menu in PixInsight.
I allowed an update to run, but no change to the script menu.
I next opened Script -> Feature Scripts and then re-added both versions of Mure Denoise using the "Add" button and navigating to the folder for each script inside PixInsight.
I am not sure what happened. Perhaps this is a glitch that only I experienced.
I hope this helps someone else.
Andrew
« Reply #2 on: 2020 February 03 09:04:22 »
Hi Andrew,
This is a machine-specific issue. The MureDenoise script is included in all 1.8.8-4 distribution packages, hence it is available once the application has been installed on all supported platforms.
