Author Topic: Advice please  (Read 4854 times)
Offline srecaldin
Advice please
« on: 2020 January 23 14:47:17 »
I am not able to start Pixinsight all of a sudden when it has been working without a problem for quite a while.  I enclose the problem details and system configuration report that is sent to Apple.
Process:               PixInsight [662]
Path:                  /Applications/PixInsight/PixInsight.app/Contents/MacOS/PixInsight
Identifier:            software.pleiades.PixInsight
Version:               ???
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           PixInsight [662]
User ID:               501
Date/Time:             2020-01-23 22:42:29.177 +0000
OS Version:            Mac OS X 10.12.6 (16G2136)
Report Version:        12
Anonymous UUID:        D86EAACC-DB55-9BF5-08A1-6D925F33965D
Time Awake Since Boot: 140 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_CRASH (Code Signature Invalid)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace CODESIGNING, Code 0x1
kernel messages:
VM Regions Near 0 (cr2):
    __TEXT                 0000000107355000-000000010872c000 [ 19.8M] r-x/r-x SM=COW  @:F [(null)]
Thread 0 Crashed:
0   d,F                              0x000000010da14000 _dyld_start + 0
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000000000000000  rcx: 0x0000000000000000  rdx: 0x0000000000000000
  rdi: 0x0000000000000000  rsi: 0x0000000000000000  rbp: 0x0000000000000000  rsp: 0x00007fff588aac48
   r8: 0x0000000000000000   r9: 0x0000000000000000  r10: 0x0000000000000000  r11: 0x0000000000000000
  r12: 0x0000000000000000  r13: 0x0000000000000000  r14: 0x0000000000000000  r15: 0x0000000000000000
  rip: 0x000000010da14000  rfl: 0x0000000000000200  cr2: 0x0000000000000000
Logical CPU:     0
Error Code:      0x00000000
Trap Number:     0
Binary Images:
       0x107355000 -        0x10872bfff +d,F (0) <FDE3F7E4-2F91-3340-BB81-C747E840A17A> d,F
       0x10da13000 -        0x10da50dc7 +d,F (434) <33DB4E37-BC29-37A4-92AB-30328E66A8FA> d,F
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 114
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=20.8M resident=0K(0%) swapped_out_or_unallocated=20.8M(100%)
Writable regions: Total=8416K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=8416K(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
STACK GUARD                       56.0M        2
Stack                             8192K        2
__DATA                            1040K        5
__LINKEDIT                         752K        3
__TEXT                            20.1M        3
shared memory                        8K        3
TOTAL                             85.8M       12
Model: iMac13,2, BootROM 287.0.0.0.0, 4 processors, Intel Core i7, 3.4 GHz, 24 GB, SMC 2.11f14
Graphics: NVIDIA GeForce GTX 675MX, NVIDIA GeForce GTX 675MX, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1600 MHz, 0x859B, 0x435438473353313630424D2E4D3136464544
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1600 MHz, 0x859B, 0x435438473353313630424D2E4D3136464544
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF4), Broadcom BCM43xx 1.0 (7.21.171.134.1a2)
Bluetooth: Version 5.0.5f7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: APPLE HDD ST1000DM003, 1 TB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: USB 3.0 Bus
USB Device: BUP BK
USB Device: USB Receiver
Thunderbolt Bus: iMac, Apple Inc., 23.4
Offline johnpane
Re: Advice please
« Reply #1 on: 2020 January 23 15:19:59 »
I had the same problem and had to re-install by downloading from the software distribution site.
Offline srecaldin
Re: Advice please
« Reply #2 on: 2020 January 24 11:18:45 »
Thanks, I will give it a whirl then.
Re: Advice please
« Reply #3 on: 2020 January 24 11:37:27 »
This is a known problem:
https://pixinsight.com/forum/index.php?topic=14562.msg87060#msg87060
The solution is simply reinstalling 1.8.8-3 and applying all updates available. Sorry for the inconvenience.
