Author Topic: version 1.8.8.3-3 errors all the time  (Read 5175 times)
Offline jshelly
« on: 2020 January 12 20:52:43 »
I cannot get through ABE and/or DBE without the latest version of PI (1.8.8.3-3) giving me error after error after error and ultimately crashes losing all data.
When the errors start PI is rendered unusable meaning that if I click on anything in PI it throws the same error which means I am unable to save my project once this error ensues if I do not act quickly.  I have seen multiple posts from other users experiencing a similar error if not the same. This issue needs to be resolved.  This is not something that is independent of PI.  Prior to the latest update I did not have these errors and PI functioned flawlessly.
I am using Windows 10 Pro version 1903 build 18362.535 x64 with an Intel (R) Core(TM) i73667U CPU @ 2.00 GHz @ 2.00 GHz, and 16 GB of RAM.   Graphics is Intel(R) HD Graphics 4000 and Touch support with 10 Touch points with Driver version 10.18.10.5100.  Hard drive is Samsung SSD 860 Pro 2TB.
Below is my entire process console copied and pasted below.  Please help.  If you need me to provide any additional information please let me know.  Please keep in mind that I am not a programmer and will not understand coding jargon.  If you would be so kind to explain what you need as plainly as possible it would be most appreciated.
Initializing PixInsight...
JavaScript runtime initialized.
Installing 49 module(s):
C:/Program Files/PixInsight/bin/Annotation-pxm.dll
C:/Program Files/PixInsight/bin/ArcsinhStretch-pxm.dll
C:/Program Files/PixInsight/bin/AssistedColorCalibration-pxm.dll
C:/Program Files/PixInsight/bin/BackgroundModelization-pxm.dll
C:/Program Files/PixInsight/bin/Blink-pxm.dll
C:/Program Files/PixInsight/bin/BMP-pxm.dll
C:/Program Files/PixInsight/bin/CloneStamp-pxm.dll
C:/Program Files/PixInsight/bin/ColorCalibration-pxm.dll
C:/Program Files/PixInsight/bin/ColorManagement-pxm.dll
C:/Program Files/PixInsight/bin/ColorSpaces-pxm.dll
C:/Program Files/PixInsight/bin/CometAlignment-pxm.dll
C:/Program Files/PixInsight/bin/Compatibility-pxm.dll
C:/Program Files/PixInsight/bin/Convolution-pxm.dll
C:/Program Files/PixInsight/bin/CosmeticCorrection-pxm.dll
C:/Program Files/PixInsight/bin/Debayer-pxm.dll
C:/Program Files/PixInsight/bin/Deconvolution-pxm.dll
C:/Program Files/PixInsight/bin/FITS-pxm.dll
C:/Program Files/PixInsight/bin/Flux-pxm.dll
C:/Program Files/PixInsight/bin/Fourier-pxm.dll
C:/Program Files/PixInsight/bin/Geometry-pxm.dll
C:/Program Files/PixInsight/bin/Global-pxm.dll
C:/Program Files/PixInsight/bin/GradientDomain-pxm.dll
C:/Program Files/PixInsight/bin/GREYCstoration-pxm.dll
C:/Program Files/PixInsight/bin/Image-pxm.dll
C:/Program Files/PixInsight/bin/ImageCalibration-pxm.dll
C:/Program Files/PixInsight/bin/ImageIntegration-pxm.dll
C:/Program Files/PixInsight/bin/ImageRegistration-pxm.dll
C:/Program Files/PixInsight/bin/INDIClient-pxm.dll
C:/Program Files/PixInsight/bin/IntensityTransformations-pxm.dll
C:/Program Files/PixInsight/bin/JPEG-pxm.dll
C:/Program Files/PixInsight/bin/JPEG2000-pxm.dll
C:/Program Files/PixInsight/bin/LocalHistogramEqualization-pxm.dll
C:/Program Files/PixInsight/bin/MaskGeneration-pxm.dll
C:/Program Files/PixInsight/bin/Morphology-pxm.dll
C:/Program Files/PixInsight/bin/MultiscaleProcessing-pxm.dll
C:/Program Files/PixInsight/bin/NoiseGeneration-pxm.dll
C:/Program Files/PixInsight/bin/NoiseReduction-pxm.dll
C:/Program Files/PixInsight/bin/NoOperation-pxm.dll
C:/Program Files/PixInsight/bin/Obsolete-pxm.dll
C:/Program Files/PixInsight/bin/PixelMath-pxm.dll
C:/Program Files/PixInsight/bin/RAW-pxm.dll
C:/Program Files/PixInsight/bin/RestorationFilters-pxm.dll
C:/Program Files/PixInsight/bin/Sandbox-pxm.dll
C:/Program Files/PixInsight/bin/SplitCFA-pxm.dll
C:/Program Files/PixInsight/bin/StarGenerator-pxm.dll
C:/Program Files/PixInsight/bin/SubframeSelector-pxm.dll
C:/Program Files/PixInsight/bin/TGV-pxm.dll
C:/Program Files/PixInsight/bin/TIFF-pxm.dll
C:/Program Files/PixInsight/bin/XISF-pxm.dll
* Scripting resources updated.
49 of 49 module(s) installed.
Processing script file: C:/Program Files/PixInsight/etc/init.pjsr/pjsr-core-defs.js
* 1 initialization script(s) executed.
Processing script file: C:/Program Files/PixInsight/etc/startup/startup.scp
* 1 startup script(s) executed.
_____________       ________            _____        ______ _____
___  __ \__(_)___  _____  _/_______________(_)______ ___  /___  /_
__  /_/ /_  /__  |/_/__  /__  __ \_  ___/_  /__  __ `/_  __ \  __/
_  ____/_  / __>  < __/ / _  / / /(__  )_  / _  /_/ /_  / / / /_
/_/     /_/  /_/|_| /___/ /_/ /_//____/ /_/  _\__, / /_/ /_/\__/
                                             /____/
PixInsight Core 1.8.8-3 Ripley (x64)
Copyright (C) 2003-2019 Pleiades Astrophoto
Welcome to PixInsight. Started 2020-01-13T03:49:00.841Z
* Parallel processing enabled: Using 4 logical processors.
* Thread CPU affinity control enabled.
* Using OpenGL ES graphics acceleration.
* PSM AutoSave enabled. Auto-save period: 30 seconds.
open "file:///C:/Users/Jenni/Pictures/2020/2020-01-08/QHY168C__Mono/C50_crop.xisf"
Reading 1 file(s):
Loading image: w=4902 h=3232 n=3 RGB Float32
ICC profile extracted: 'sRGB IEC61966-2.1', 3144 bytes.
82 FITS keyword(s) extracted.
ChannelExtraction: Processing view: C50_crop
Extracting RGB channels: done
2.501 s
AutomaticBackgroundExtractor: Processing view: C50_crop_R
* Sample box generation and rejection:
Channel #0
Generating background samples: done
  45679 background samples.
* Computing interpolating polynomials:
Channel #0
Setting up least squares system matrix: done
* Building background model image:
Channel #0
Interpolating background model pixels: done
* Applying background model:
Dividing by background model: done
Normalizing corrected image:
Rescaling samples:   0%
Computing extreme sample values: done
3.900 s
AutomaticBackgroundExtractor: Processing view: C50_crop_G
Channel #0
  43423 background samples.
Channel #0
Channel #0
3.891 s
Channel #0
  39197 background samples.
Channel #0
Channel #0
3.774 s
Channel #0
  50830 background samples.
Channel #0
Channel #0
3.875 s
ImageIdentifier: Processing view: C50_crop_G_ABE1
id = C50_crop_G_ABE
6.960 ms
AutomaticBackgroundExtractor: Processing view: C50_crop_B
Channel #0
  56765 background samples.
Channel #0
Channel #0
3.941 s
Channel #0
  57380 background samples.
Channel #0
Channel #0
3.928 s
ImageIdentifier: Processing view: C50_crop_B_ABE1
id = C50_crop_B_ABE
7.249 ms
Writing project:
C:/Users/Jenni/Pictures/2020/2020-01-08/QHY168C__Mono/c50/C50_new.pxiproject
* Project bundle directory created: C:/Users/Jenni/Pictures/2020/2020-01-08/QHY168C__Mono/c50/C50_new.pxiproject
* Project data directory created: C:/Users/Jenni/Pictures/2020/2020-01-08/QHY168C__Mono/c50/C50_new.pxiproject/project.data
* Estimated uncompressed project size : 544.570 MiB
* Available on target device          : 148.766 GiB (7.808 %)
* Writing 7 image window(s)
Writing image: C50_crop_R_ABE
Writing image: C50_crop_G
Writing image: C50_crop_G_ABE
Writing image: C50_crop_B_ABE
* Embedding project thumbnail image
* Project seal generated, SHA1 checksum = d60facbe01f6b176ef19963e28406be59f5419ff
* Project generated OK.
25.273 s
ChannelCombination: Global context
Combining RGB channels: done
1.024 s
ImageIdentifier: Processing view: Image17
id = C50_Crop_ABE_RGB
6.874 ms
Writing project:
* Estimated uncompressed project size : 725.896 MiB
* Available on target device          : 148.413 GiB (7.789 %)
* Writing 8 image window(s)
Writing image: C50_Crop_ABE_RGB
* Existing project files preserved: 7, 364.121 MiB
* Project seal generated, SHA1 checksum = 1ffd6af1e7f94e1812817980b0883780c3650b48
* Old project files removed: 1, 179.964 KiB
7.828 s
DynamicBackgroundExtraction: Processing view: C50_Crop_ABE_RGB
Generating model channel #0
2-D surface spline interpolation: done
Generating model channel #1
Generating model channel #2
Applying background correction: done
7.677 s
7.851 s
8.044 s
*** PCL Win32 System Exception: At address 00007FF93F0A6240 with exception code C0000005 :
Access violation: invalid memory read operation at address 0000000000000008
*** Backtrace Information ***
  0: E in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0x7F3135D0
  1: _C_specific_handler in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x767CB860
  2: is_exception_typeof in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x767C22E0
  3: is_exception_typeof in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x767C22E0
  4: is_exception_typeof in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x767C22E0
  5: _CxxFrameHandler3 in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x767CC100
  6: _chkstk in module: C:\WINDOWS\SYSTEM32\ntdll.dll at address: 0x7F3610E0
  7: RtlRaiseException in module: C:\WINDOWS\SYSTEM32\ntdll.dll at address: 0x7F329EF0
  8: KiUserExceptionDispatcher in module: C:\WINDOWS\SYSTEM32\ntdll.dll at address: 0x7F35FE40
  9: QWidget::windowHandle in module: C:\Program Files\PixInsight\bin\Qt5Widgets.dll at address: 0x3F0A6240
 10: QAccessibleWidget::window in module: C:\Program Files\PixInsight\bin\Qt5Widgets.dll at address: 0x3F27A0E0
 11: QAccessibleWidget::window in module: C:\Program Files\PixInsight\bin\qt-plugins\platforms\qwindows.dll at address: 0x3F27A0E0
 12: QAccessibleWidget::window at address: 0x3F27A0E0
  0: E in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0x0
  0: E in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0x80E43C30
8.944 s
  0:  in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0xFF000000
  0:  in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0x0
Writing project:
* Estimated uncompressed project size : 1.285 GiB
* Available on target device          : 148.265 GiB (7.781 %)
* Writing 12 image window(s)
Writing image: C50_Crop_ABE_RGB_background
Writing image: C50_Crop_ABE_RGB_DBE2
Writing image: C50_Crop_ABE_RGB_DBE3
* Existing project files preserved: 8, 497.418 MiB
* Project seal generated, SHA1 checksum = 574ba4bbead01a78823a33dd72a60c0b27a6db58
* Old project files removed: 1, 263.655 KiB
24.011 s
  0:  in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0x7F2FBA17
  0:  in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0x4C
  0:  in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0x7A376102
ImageIdentifier: Processing view: C50_Crop_ABE_RGB_DBE3
id = C50_Crop_ABE_RGB_DBE_Final
9.770 ms
Writing file:
C:/Users/Jenni/Pictures/2020/2020-01-08/QHY168C__Mono/C50_Crop_ABE_RGB_DBE_Final.xisf
Writing image: w=4902 h=3232 n=3 RGB Float32
16 FITS keyword(s) embedded.
RGBWS parameters embedded.
Display function parameters embedded.
ICC profile embedded: 'sRGB IEC61966-2.1', 3144 bytes.
Offline WillB
Re: version 1.8.8.3-3 errors all the time
« Reply #1 on: 2020 January 14 03:04:50 »
For troubleshooting, as a first step try updating your intel drivers.
Your graphics driver seems very old, current version for intel HD4000 is 15.33.49.5100.
Intel provide a handy driver checker tool that will check all your system intel drivers, highlight any that need updating and install them for you.
You will find the link to the tool at the top-left of the graphics driver download page and it is a good idea to use the tool in preference to manually installing updated drivers one-by-one however the choice is yours, use the tool or install the latest graphics driver manually:
https://downloadcenter.intel.com/download/29311/Intel-Graphics-Driver-for-Windows-15-33-?v=t
Is your computer a touch screen enabled Surface Pro? There were lots of problems with those and intel HD4000 graphics a few years ago.
The other issue that appears fairly often is conflicts with other software running in the background on the machine and you may need some detective work by using task manager, looking to see which additional non-windows programmes are running in the background and stopping them before launching PI. If the errors cease then one of those background programmes is in conflict with PI.
Offline jshelly
« Reply #2 on: 2020 January 14 18:12:14 »
Thanks for the responsel
I installed the latest driver directly from Intel’s website that was released less than a week ago.  The driver version I listed in my OP was what Device Manager reported.  I will double check and use Intel’s Tool and report back.  My PC is a Sony VAIO Tap 20.  I will run a Task Manager during my next session to sniff out any background processes that might be causing errors in PI.
Offline jwaters125
« Reply #3 on: 2020 January 21 22:33:56 »
If the Intel diver doesn't work try installing the PC manufacturer device driver from their website.
