Author Topic: Application crashes regularly  (Read 4043 times)
Offline txo
« on: 2020 January 04 02:29:31 »
Hello,
Application often crashes after performing the same task again and again and needs to be restarted. Example would be image calibration or dbe. It's quite annoying and is in the SW for more than a year now since I started using PI. Sometimes the operation needs to be run several dozen times, sometimes few times is enough to get this error.
example stack trace:
AutomaticBackgroundExtractor: Processing view: integration_DBE_DBE
* Sample box generation and rejection:
Channel #0
Generating background samples: done
  50199 background samples.
* Computing interpolating polynomials:
Channel #0
Setting up least squares system matrix: done
* Building background model image:
Channel #0
Interpolating background model pixels: done
* Applying background model:
Subtracting background model: done
Normalizing corrected image:
Rescaling samples:   0%
Computing extreme sample values: done
*** PCL Win32 System Exception: At address 00007FF9BEC56240 with exception code C0000005 :
Access violation: invalid memory read operation at address 0000000000000008
*** Backtrace Information ***
  0:  in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0x0
  1: _C_specific_handler in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x651B860
  2: is_exception_typeof in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x65122E0
  3: is_exception_typeof in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x65122E0
  4: is_exception_typeof in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x65122E0
  5: _CxxFrameHandler3 in module: C:\Program Files\PixInsight\bin\VCRUNTIME140.dll at address: 0x651C100
  6: _chkstk in module: C:\WINDOWS\SYSTEM32\ntdll.dll at address: 0x173E10E0
  7: RtlRaiseException in module: C:\WINDOWS\SYSTEM32\ntdll.dll at address: 0x173A9EF0
  8: KiUserExceptionDispatcher in module: C:\WINDOWS\SYSTEM32\ntdll.dll at address: 0x173DFE40
  9: QWidget::windowHandle in module: C:\Program Files\PixInsight\bin\Qt5Widgets.dll at address: 0xBEC56240
 10: QAccessibleWidget::window in module: C:\Program Files\PixInsight\bin\Qt5Widgets.dll at address: 0xBEE2A0E0
 11: QAccessibleWidget::window in module: C:\Program Files\PixInsight\bin\qt-plugins\platforms\qwindows.dll at address: 0xBEE2A0E0
 12: QAccessibleWidget::window at address: 0xBEE2A0E0
 13: QAccessibleWidget::window at address: 0xBEE2A0E0
 14: QAccessibleWidget::window at address: 0xBEE2A0E0
 15: QStyleSheetStyle::event in module: C:\Program Files\PixInsight\bin\Qt5Widgets.dll at address: 0xBECB0460
 16: QApplicationPrivate::notify_helper in module: C:\Program Files\PixInsight\bin\Qt5Widgets.dll at address: 0xBEC18F80
 17: QApplication::notify in module: C:\Program Files\PixInsight\bin\Qt5Widgets.dll at address: 0xBEC163F0
 18: QApplication::notify in module: C:\WINDOWS\system32\UIAutomationCore.dll at address: 0xBEC163F0
  0: ?ì in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0xED0320
  0:   in module: C:\Program Files\PixInsight\bin\PixInsight.exe at address: 0xFFFFFFFE
4.427 s
Offline dave_galera
    • QDigital Astro
Re: Application crashes regularly
« Reply #1 on: 2020 January 04 05:28:51 »
Can you post an image so it can be investigated, and what version of PI are you using?
Dave
Offline SkyExplorer
« Reply #2 on: 2020 January 04 06:59:52 »
