Author Topic: Weighted Batch Preprocessing error with 1-2 lights  (Read 889 times)
Offline RalphPaonessa
« on: 2019 December 30 14:33:34 »
When I have only 1-2 light frames, I get the Weighted Batch Preprocessing error "Cannot integrate less than 3 Light frames," which makes sense.
However, even if I disable Image Integration or specify Calibrate Only, this error persists and won't let me proceed. I simply want to calibrate and align those frames. It seems that I should be able to do this even with 1-2 subs for a filter.
Is there a way around this?
Ralph
« Last Edit: 2019 December 30 17:56:54 by RalphPaonessa »
Offline John_Gill
Re: Weighted Batch Preprocessing error with 1-2 lights
« Reply #1 on: 2019 December 30 23:52:30 »
The easiest way to solve this, is to duplicate the two images and then run the process with the 4 frames.  (There is some math issue with only two images ... I should have paid more attention at school).
space is not black
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
« Reply #2 on: 2019 December 31 10:47:17 »
Thanks, John, that's a clever work-around.
I assume the problem with only 2 images is that you can't do effective statistics/rejection without more samples.
If that's the case, then maybe WBPP can be altered so that this isn't a limitation if you specify Calibrate Only.
Ralph
Offline John_Gill
« Reply #3 on: 2020 January 01 02:38:15 »
Put your suggestion on the "Wish-List" on this forum.
John
