Author Topic: Problem with Canon EOS 4000D  (Read 842 times)
Offline NH
« on: 2019 December 21 06:52:44 »
Hi everyone,
I want to calibrate some old data from my first camera, a Canon EOS 4000D, which I didn't processed yet. During image calibration of the raw files, I get the warning that the image geometry is incompatible. The reason from my point of view is that PixInsight recongnizes the raw files as from a Canon EOS 3000D (and not 4000D). As a consequence the raw dimensions and the CFA pattern are wrong (also but not important the focal lenght). The message in the process console is the following:
Camera ........... Canon EOS 3000D
Timestamp ........ 2019-08-22T22:44:28Z
Exposure ......... 361s
ISO speed ........ 1600
Focal length ..... 50 mm
CFA pattern ...... Bayer GBRG
Raw dimensions ... w=5344 h=3516
Image geometry ... x=142 y=52 w=5202 h=3464
Raw decoding parameters:
Output mode ............... cfa
Auto crop ................. enabled
Wavelet noise threshold ... 0
White balancing ........... disabled
Black point correction .... disabled
Highlights clipping ....... disabled
Auto rotate ............... disabled
Output image .............. w=5202 h=3464 n=1 Gray
Reading RAW data: done
*** Error: Incompatible image geometry
In the past I have calibrated the raw files from my Canon EOS 4000D without any problems. And PixInsight recongnized the raw files as from a Canon EOS 4000D.
I have the latest version 1.8.8-3 running. The Raw Format Preferences are set to Pure Raw.
Has anyone an idea what I have to do to get it work properly again?
Offline John_Gill
Re: Problem with Canon EOS 4000D
« Reply #1 on: 2019 December 21 09:15:33 »
I have also been playing with old DSL data and get the same error.  My Master_Dark, Master_Flats and Super_Bias are 5202 x 3465 and the Lights 5202 x 3464. These image processed before, so a bit strange.  Anyway, I just cropped the the Masters to match the Lights and then everything worked.
space is not black
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
« Reply #2 on: 2019 December 21 14:25:18 »
you gotta be careful with that crop to make sure you preserve the bayer matrix properly.
if you are using master darks/bias which were created a long time ago there is a chance that the various changes to how PI decodes DSLR files is the cause. also, there was a change to libRaw recently that broke things for those of us doing AP... you can check this thread for some more info:
https://pixinsight.com/forum/index.php?topic=14219.0
Offline NH
« Reply #3 on: 2019 December 22 03:34:16 »
Hi Rob,
thank you! That was the problem and the solution.
Fortunatly I found my old calibration files on an external hard drive. So I can create new masters and there is no need for the workaround for me. Furthermore I found out that the Canon EOS 4000D is called Canon EOS 3000D in some regions.
Nils
Offline John_Gill
« Reply #4 on: 2019 December 22 08:48:03 »
Hey pfile, thanks for the heads-up about cropping and the bayer matrix.  I was wondering what went wrong with the integration  :tongue:
