Author Topic: Error: Parsing EGAIN . . .  (Read 703 times)
Offline GordonH
« on: 2019 December 12 12:22:34 »
I'm getting the following error message consistently:
"Error: Parsing EGAIN FITS keyword: Parsing 64-bit floating point expression ISO1600" (With a "^" under the "I" is ISO)
I'm using TheSkyX Camera add on to control my Canon 6D. TheSky is using the EGAIN keyword to store the ISO setting. I understand that PixInsight is expecting a numeric in this field and not text. My question, since everything seems to process OK what may be going wrong unseen?
Gordon Hansen
Offline bulrichl
Re: Error: Parsing EGAIN . . .
« Reply #1 on: 2019 December 12 13:12:15 »
This is an improper usage of the FITS keyword "EGAIN".
From FITS File Header Definition (from https://diffractionlimited.com/help/maximdl/FITS_File_Header_Definitions.htm ):
EGAIN – electronic gain in photoelectrons per ADU.
ISOSPEED – ISO camera setting, if camera uses ISO speeds.
Please ask Software Bisque for using the correct FITS keyword.
Bernd
Offline GordonH
« Reply #2 on: 2019 December 13 12:21:52 »
Yes, I understand its an improper use of the keyword. My question is what is or is not being calculated correctly because its missing>
Gordon
Offline bulrichl
« Reply #3 on: 2019 December 13 14:50:55 »
As far as I know neither EGAIN nor ISO is evaluated by a PixInsight process. The processing should be performed correctly.
Bernd
