Author Topic: How to enable TRACK VIEW as default  (Read 712 times)
Offline Cosmick
« on: 2019 December 06 00:54:04 »
I have a set of Process Icons that load when I start Pixinsight. Several have the option to "Track View" but even if I have it enabled when I save the process instance it does not stick and I have to re-enable it each time.
Is there any way to have "Track View" enabled as the default as I pretty much always have it turned on when using Levels, Curves and STF ?
Clear Skies
Mick
Re: How to enable TRACK VIEW as default
« Reply #1 on: 2019 December 06 07:46:43 »
Hi Mick,
The track view option cannot be enabled by default, nor can it be enabled through process icons. You can save a project, where the state of track view options for open tool windows is serialized and restored when you open the project.
Offline John_Gill
« Reply #2 on: 2019 December 07 09:03:21 »
mmmh, maybe it should go in the “Wish List”
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline Cosmick
« Reply #3 on: 2019 December 07 16:40:17 »
OK. Any possibility of this being available in the future ?
Thanks. I'll try this.
Clear Skies
Mick
« Reply #4 on: 2019 December 08 01:56:37 »
No, the Track View option cannot be enabled by default for several reasons.
Processes, process instances and images are completely independent and self-sufficient objects. This is a consequence of PixInsight's object-oriented design. The track view functionality is borderline in this context. It has been designed as a special working mode, available on some process interfaces as a convenience feature. It is not intended to be part of these processes, nor the way these processes work normally, and should only be used in special cases where an increased level of interaction with several images can be useful temporarily. On the other hand, the track view feature can have a non-negligible cost in terms of resource consumption, which would affect negatively the performance of the whole platform if it were enabled systematically.
Offline Cosmick
« Reply #5 on: 2019 December 08 13:47:29 »
I suspected as much. Thanks for the explanation.
Clear Skies
Mick
