I am trying to remove some stubborn sat trails in my stack of 100 subframes. I have been looking at the rejection_high image that is available after I run the ImageIntegration process and it does show significant rejection around this sat trail, but the stacked image still has some trailing. So, I enabled the "Reject high large-scale structures" and re-ran ImageIntegration with "Generation rejection maps" checked.
The process console indicated that it generated the high large-scale rejection map, but no such image was available when the ImageIntegration process completed.
Is the high large-scale rejection map included in the regular rejection_high image, or should it have generated a separate image for the large-scale rejection map?
I am using the new ESD rejection algorithm in PI 1.8.8. Linear-fit rejection also did not remove this streak.
Greg
