Author Topic: Cannot Find PSFImage  (Read 755 times)
Offline mlamb1
« on: 2019 October 29 14:00:47 »
I Cannot Find PSFImage.  I am running 1.8.7, and am a new issuer, having bought PI a few weeks ago.
Last week, I used PSFImage several times, and it was under Scripts,Render (at least I think it was).
Today, I cannot find PSFImage; not under Scripts,Render or Scripts,Utilities.
Where is it?
Offline sreilly
Re: Cannot Find PSFImage
« Reply #1 on: 2019 October 29 14:09:46 »
Look under Scripts|Render..
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline mlamb1
« Reply #2 on: 2019 October 29 14:11:12 »
As I said in the original post, it is no longer in Script/Render
Offline mlamb1
« Reply #3 on: 2019 October 29 14:12:22 »
I also tried Updating the Repositories
Offline fkloer
« Reply #4 on: 2019 October 29 17:14:51 »
I found it under Script/Render also.
Good viewing, Clear skies
« Reply #5 on: 2019 October 29 17:17:02 »
did you apply any PI updates? there are 2 things to try:
open up Scripts > Feature Scripts... and click regenerate. also make sure if you see PSFImage in the list that it has a check mark next to it.
if that doesn't work, download it from http://www.skypixels.at/pixinsight_scripts.html again and install it again. it's an add-on script and does not ship with pixinsight, so if you upgrade you need to reinstall it.
Offline mlamb1
« Reply #6 on: 2019 October 30 07:00:59 »
I went to Scripts > Feature Scripts to Regenerate and PSFImage was NOT on the list.
I originally got PSFImage from adding the Repository, not from installing individually.
It was there and working last week, but gone now.
Offline mlamb1
« Reply #7 on: 2019 October 30 07:33:16 »
I went to a different PC, a HP Z840 that will be my main PC after I get the 2nd CPU installed (to give me 24 Xeon cores for PI), and added the HVB Repository, closed PI, reopened PI, and the PSFImage was there.  This is like it was on my current Z440 last week.
So on my Z440, I
1) removed the HVB Repository,
2) Checked for Updates,
3) closed PI, reopened PI,
4) added the HVB Repository, Checked for Updates,
5) closed PI, reopened PI
Still, PSFImage was NOT there.
Do I need to uninstalled and then reinstall PI?
Offline bulrichl
« Reply #8 on: 2019 October 30 07:37:46 »
You don't need to install Hartmut's scripts individually. Add the link provided by pfile with 'Mange Update Repositories', then execute 'Check for Updates'-
Bernd
Offline mlamb1
« Reply #9 on: 2019 October 30 07:52:24 »
Since removing the HVB Repository and adding it back did not work.  I uninstalled PI and reinstalled PI.
Upon relaunching PI, it notified of 5 Updates (including HVB), which I OK'ed.  After again closing/opening PI, PSFImage is finally back.
I would still like to know, why did it go away?
