Author Topic: New install on linux box, cancels the install.  (Read 533 times)
Offline Wesley R Handrow
« on: 2019 September 17 12:21:11 »
__  /_/ /_  /__  |/_/__  /__  __ \_  ___/_  /__  __ `/_  __ \  __/
_  ____/_  / __>  < __/ / _  / / /(__  )_  / _  /_/ /_  / / / /_
/_/     /_/  /_/|_| /___/ /_/ /_//____/ /_/  _\__, / /_/ /_/\__/
                                             /____/
PixInsight X11 UNIX/Linux installer version 01.08.06.1473 Ripley
Copyright (C) 2003-2019 Pleiades Astrophoto. All Rights Reserved
PixInsight will be installed with the following parameters:
Source installation directory ... /home/wrh/pi-install/PixInsight
PixInsight core application ..... /opt/PixInsight
Application desktop entry ....... /usr/share/applications/PixInsight.desktop
Application icons directory ..... /usr/share/icons/hicolor
MIME type description file ...... /usr/share/mime/packages/PixInsight.xml
Create /bin launcher script ..... yes
Remove previous installation .... yes
==> Are you sure [yes|no] ? y
** Canceled
 When I type "yes" this is what happens,
                                             /____/
==> Are you sure [yes|no] ? yes
Please wait while PixInsight is being installed...
Illegal instruction
Why is this not working?
Offline jwaters125
Re: New install on linux box, cancels the install.
« Reply #1 on: 2019 September 17 13:50:37 »
What Linux / release...?
Offline copello
« Reply #2 on: 2019 September 18 02:55:47 »
Did you run the install with
sudo or as user root?
« Reply #3 on: 2019 September 18 23:46:50 »
Linux Mint cinnamon ver. 19.1 Tessa, not at that machine right now. That's a flavor of Ubuntu. I tried running the command as both su (root) and sudo and either received a cancel or illegal command. The help files need to be updated since they tell you to enter an old version number.
« Reply #4 on: 2019 September 19 04:32:38 »
Illegal instruction
PixInsight 1.8.6 requires a processor with SSE4.1 instructions support. Which processor are you using in this machine?
