Author Topic: Statistics RBG vs K...?  (Read 520 times)
Offline fatboy1271
« on: 2019 September 17 06:51:16 »
I've been getting help on my Flats and a new confusion has been added. When I load a CR2 into Statistics I have one column K. When the people helping load that same file they have RGB...? I've been going crazy trying figure out why my Mean reading wasn't the same and then I finally realized this difference.
I looked in the Statistics options and even turned everything on, but still no RGB. How do I change from K to RGB? Attached are screenshots.
Thank you,
fat
Re: Statistics RBG vs K...?
« Reply #1 on: 2019 September 17 08:03:22 »
they have their RAW module set to debayer CR2 files and you don't. therefore you get a greyscale CFA image (one channel) and they get 3 channel RGB.
if you want to see what they are seeing you can just use the Debayer module to debayer your flat. then when you look at the stats of the debayered flat you'll see RGB.
Offline fatboy1271
« Reply #2 on: 2019 September 17 08:31:52 »
Thanks rob!!!
