Among many other things, I have changed (hopefully to improve
If your images are not undersampled, the drizzle algorithm will not improve anything.
This is true for the original drizzle method, i.e. with a scaling factor > 1.
...a drizzle integrated image always loses some signal (the amount of lost signal is directly proportional to the drizzle subsampling ratio)
Again, true when the drizzle scaling factor (or subsampling ratio) is 2 or larger.
The *huge* benefit of drizzle integration is the total absence of pixel interpolation. This means absolutely no ringing and no aliasing artifacts, which is really great.
Always true.
If using raw CFA data, enable CFA drizzle. If the images are undersampled and the amount of frames is reasonable, use drizzle x2. Otherwise, or if preserving the original scale is preferred, use drizzle x1.
This is what I think currently. When applicable, drizzle always is, IMHO, the best way to integrate deep-sky data. Fortunately, drizzle is very well integrated with the entire preprocessing toolset in PixInsight, and even more in the next 1.8.7 version.
