Author Topic: CometAlignment saving issue in drizzle mode with operand image  (Read 1175 times)
Offline jpaana
Currently when using CometAlignment in drizzle mode with operand image the comet aligned result is not saved correctly and is identical to star aligned result image. Reason seems to be a copy & paste error in the code:
void CometAlignmentInstance::SaveImage ( CAThread* t)
Save(t->TargetImage(), t, 0); //Save result image
if(t->StarAligned()) //Save PureStarAligned
ImageVariant* img = new ImageVariant(t->StarAligned());
Save(img, t, 1);
delete img, img = 0;
if(t->CometAligned()) //Save PureCometAligned
ImageVariant* img = new ImageVariant(t->StarAligned());   // <-- this should probably be t->CometAligned()?
Save(img, t, 2);
Re: CometAlignment saving issue in drizzle mode with operand image
« Reply #1 on: 2019 September 09 07:10:16 »
Bug confirmed. This is now fixed in version 1.8.7. Thank you for reporting and for your spot-on solution.
