Author Topic: DSLR - Cosmetic Correction and Dithering  (Read 650 times)
Offline jwaters125
« on: 2019 July 30 22:10:17 »
Simple question - If a person does a good job at Dithering (moving the mount enough, Dithering every frame ...) is doing Cosmetic Correction necessary?  Do you gain anything?
I use a Ha Mod Canon 6D and stock Canon 5DMkIV.
Offline acmalko
Re: DSLR - Cosmetic Correction and Dithering
« Reply #1 on: 2019 July 30 23:09:09 »
Yes !
You still have hot or deviant pixels after the masterdark substraction
Offline dld
« Reply #2 on: 2019 July 30 23:42:05 »
Hello, I have the 6D too and I don't do cosmetic correction. Dithering deals well with any hot/cold/stuck pixels and helps a lot with fixed-pattern noise.
(edited after Andres' comment)
« Last Edit: 2019 July 31 07:41:22 by dld »
Offline jwaters125
« Reply #3 on: 2019 July 31 00:13:17 »
There are my thoughts too but I have come across several posts saying it makes a small improvement.
If I don't Dither I do Cosmetic Correction.
Offline bulrichl
« Reply #4 on: 2019 July 31 01:02:49 »
I consider dithering even more important than cosmetic correction: dithering will attenuate / remove fixed pattern noise, cosmetic correction cannot achieve that.
Bernd
Offline Geoff
« Reply #5 on: 2019 July 31 01:20:23 »
And besides, cosmetic correction invents data to replace the defects. Dithering preserves the original data.
Don't panic! (Douglas Adams)
Offline dave_galera
    • QDigital Astro
« Reply #6 on: 2019 July 31 04:12:06 »
Another vote for dithering over cosmetic correction
Dave
Offline Andres.Pozo
« Reply #7 on: 2019 July 31 06:38:29 »
Pixel rejection is done after the interpolation in StarAligment. The interpolation of PixInsight works great but it can not avoid spilling the value of the bad pixel into the surrounding pixels. The surrounding pixels now have a slightly higher value that is below the rejection threshold but can skew the mean.
I do both: CosmeticCorrection and Dithering.
