Author Topic: Drizzle on one shot color DSLR  (Read 535 times)
Offline Andyc421
« on: 2019 July 21 17:22:09 »
has anyone successfully used Drizzle on DSLR before
I followed
Warrens PI 22 and that did not work
I followed up on a later posting of his that showed the Bayer drizzle added to BPP but my version (latest version of PI) does not have that box to check
any suggestions
Sorry if this has been posted before
if so just point me to the thread I couldnt seem to find it
thanks in advance
Offline ngc1535
Re: Drizzle on one shot color DSLR
« Reply #1 on: 2019 July 21 21:14:52 »
It worked fine for me when I drizzled the debayered images from OSC data.
What steps did you take?
What was the issue you encountered?
When I did it, I outputted Drizzle data from Star Alignment...and then I subsequently used Drizzle Integration on each of the color sets.
-adam
Offline wvanreeven
« Reply #2 on: 2019 July 21 23:40:12 »
I have used drizzle on DSLR data a lot but I never used BPP. I always did everything manually. As Adam says, tick the drizzle box in StarAlignment and tick it in ImageIntegration. Then perform a DrizzleIntegration. See for instance this workflow
https://www.lightvortexastronomy.com/tutorial-pre-processing-calibrating-and-stacking-images-in-pixinsight.html
HTH, Wouter
Offline bulrichl
« Reply #3 on: 2019 July 22 01:34:54 »
No problem to use Drizzle on DSLR data.
Adam and Wouter have outlined the procedure. I want to complement that in ImageIntegration you have to apply 'Add Files' twice, once for the registered light frames and once for the Drizzle files (which were created by StarAlignment). In DrizzleIntegration I found that I had to input the directory where the calibrated light frame reside into 'Format Hints / Input directory'. 'Enable CFA drizzle' has to be checked in DrizzleIntegration.
What error message is appearing in which step of your procedure?
Bernd
« Reply #4 on: 2019 July 22 04:38:10 »
This is only necessary if you have moved the calibrated frames to a different directory on your filesystem after image registration, or if you have moved the data to a different filesystem (e.g., a different computer or network). The original location of the calibrated data is always stored in .xdrz files.
You can also drag the whole set of .xisf and .xdrz files from File Explorer to ImageIntegration, or the folder that contains all of them. ImageIntegration will detect and associate images and drizzle data files automatically. Also works if you drag from a system or desktop file manager application.
