Author Topic: Manually Rotating Images  (Read 548 times)
Offline BobinBend
« on: 2019 June 22 17:34:52 »
The IMAGE/GEOMETRY pulldown allows me to manually rotate an image 90 or 180 degrees, which is quite useful. But is there a way in PI to manually rotate an image at 45 degrees or any other rotation amount? I've looked at Dynamic Crop but it doesn't seem to move the image, only the image within the window, if that makes sense.
There are times when I'd like to rotate the image to match another sky image from another source.
Thanks for your help.
Bob
Offline aworonow
    • Faint Light Photography
Re: Manually Rotating Images
« Reply #1 on: 2019 June 22 17:43:15 »
You probably have found it by now: Process<Geometry>Rotation. (Rotation...not FastRotation)
« Reply #2 on: 2019 June 22 22:23:50 »
you can also use ImageRegistration in non-global mode: load the reference image from a View (or File) and then apply the process to the image you want to rotate (rather than hitting the global button which is how we normally use it)
Offline BobinBend
« Reply #3 on: 2019 June 23 15:58:28 »
Thanks to both of you! I'll give them a try!
Bob
