Author Topic: Clone stamp no longer making sharp edges  (Read 793 times)
Offline aworonow
    • Faint Light Photography
« on: 2019 June 16 07:16:56 »
I need to paint a sharp-edged circle to guide DefectMap to an area in need of repair. I used to do this all the time using clone stamp to make the circle on a copy of the image (as per attached image) then manipulating that into a template for the defect map. But it stopped making sharp-edged circles. See attached.
Any ideas what I'm doing wrong or what has changed?
Offline oldwexi
    • Astronomy Pages G.W.
Re: Clone stamp no longer making sharp edges
« Reply #1 on: 2019 June 16 10:20:48 »
In case this issue persists i recommend to use the script
GAME
It allows drawing of geometric figures with soft and/or hard edges by using the
mouse. The result can be used inverted as input for DefectMap
Gerald
Offline aworonow
« Reply #2 on: 2019 June 16 16:52:56 »
Thanks Gerald, GAME would work for most of the images. But on some, a clone stamp to pull green circles from one image and post them to another (with subsequent conversion of the green to black on white for a defect map) is so much easier if a large number of spots must be corrected (or stars removed).
A.
